SR Idle Issue
Having issues with my SR Idle. It consistently hangs at around 1.5k for 3-4 seconds after coming to a stop. In the video you can see where I push the clutch causing the idle to drop, then it revs back up to 1.5k and hangs for a bit, then finally drops again. One other odd thing, if I push the clutch the revs will stay at 1.5k until I come to a complete stop, no matter how long that takes). When it is warm out the idle will drop pretty low (550-600 rpms), but when it is cooler out (as it was in the video), the idle will only drop to 1k. When I let off the throttle to shift, it also feels like the revs hang for a moment before dropping. Anyone have any ideas of what could be causing these symptoms?
![]() Join Date: Jul 2005
you might be using an automatic ECU on a manual transmission car,
something to do with the ECU probably watching the VSS and adding idle speed to keep the engine from bogging. It seems computer related. It could also be a learned feature, if you have electric fans that bring the idle down, or other electronic power drains which lower engine RPM, the ecu will LEARN to keep the idle up due to the drain... and then when the engine is cold (fans are not on) the extra airflow is still added ( the ecu doesn't know when the fans are on or off ) and so the idle goes higher. |
#4 | |
