T28 oil drain setup
Piecing together a setup on a friends car and have some questions about an the oil drain flange/setup. We don't have the stock oil return flange.
The Nissan oil drain tube is pretty expensive for such a small piece - $45 Nissan S14/S15 T28 SR20DET Oil Drain Return Tube (Turbo to Block) Would this setup work instead? Flange Turbo Oil Drain Flange 8AN Garrett T2 T25 T28 TB02 TB28 | eBay Hose fitting NEW 8 AN - Aeroquip Straight Hose End Fitting | eBay I also saw this fitting, but don't think it's as good as the one above. Any comments or suggestions? http://cgi.ebay.com/AN8-8AN-AN-8-Hos...item4cf667b446 For any other noobs like myself, here's a great video showing how the fitting works: http://eaavideo.org/video.aspx?v=46881475001 Thanks Last edited by mrbrody703; 04-22-2011 at 02:22 AM.. Reason: added video |
![]() Join Date: Jan 2003
The oem one is worth it. If you shop around you can find it cheaper usually. I used the AN fitting setup and I'm just not as happy with it and switched back to OEM, it lines up better
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
A/N mostly for looks in this case. There is no pressure going through this line. Only a gravity drain. You can use a T25 flange pipe if you have one. Slot the holes and Buy some hose from vato zone.
![]() Join Date: Nov 2007
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
MyNismo.com - SR20DET S14 / S15 TURBO OIL HOSE & TUBE KIT
this is the same price as the fr sport link but you get the hose as well |
hit up Russell at nissanparts.cc
NissanParts.cc - Your #1 Source for OEM Parts and Accessories $24.61+shipping on the T28 drain tube. I went through the hassle of reslotting and bending the one off my t25 as well but I still had issues with the hose rubbing on the steering column. |
Thanks guys, I'll go with the OEM tube. It wasn't that the piece cost too much. I was under the assumption that I could go with an A/N setup for the same cost, but it's actually worse than OEM for this use.
