Old 01-26-2009, 08:31 PM   #1
silviakid2790
silviakid2790 is an unknown quantity at this point
s14 guys.. show me pics of your rear strut bar setups :) ..need ideas for mine
need ideas on how to run my rear cusco in my s14. id like to see how you guys cut the metal cover thing in the back
silviakid2790 is offline   Reply With Quote
Old 01-26-2009, 09:42 PM   #2
projectRDM
projectRDM's Avatar
There's only one way to install it, what idea did you need? And you do NOT cut any metal at all, period. There's no modifications required to install it. Bolt in and tighten.
FORMERLY R240NA
Old 01-26-2009, 09:53 PM   #3
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
huh? this is for s14, not s13..... s13s do bolt in, s14s have a metal shroud kind of thing that MUST be cut
bump for muh rooom mate
((sr)) kelly is offline   Reply With Quote
Old 01-26-2009, 10:00 PM   #4
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
There is a picture request thread
palmdale_mob is offline   Reply With Quote
Old 01-26-2009, 10:03 PM   #5
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
No. Total fail. I have a Cusco OS. It fits fine, you just gotta flip the rear seat down and have a look. Its tough getting it in there at first, but that's it.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
#/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-26-2009, 10:09 PM   #6
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Send a message via ICQ to EDacIouSX Send a message via AIM to EDacIouSX Send a message via MSN to EDacIouSX Send a message via Yahoo to EDacIouSX
wtf are u guys like retarted or something. there's two types of rearstrut bars for S14s. one that goes through the pass through behind the seat and another that goes up and over the rear deck... explain to me WHAT do you have to cut??? sounds to me like you guys tried to install the underpass cusco strut bar upside down....
epic FAILURE
EDacIouSX is offline   Reply With Quote
Old 01-26-2009, 11:11 PM   #7
projectRDM
projectRDM's Avatar
Absolute fail. I've had a Cusco rear bar since 1998. There's two slots on the shock tower, towards the front of the tower. The endplates slide right through them. You do have to twist it in place, they don't just fall in, but if you start with it pointing down and turn it as it drops it goes in fine. It helps to have the shock out so you can clear the top studs coming through, but it's not required.
The Nismo bar goes above the deck, and obviously you have to cut the rear deck cover to fit it. I have both bars on my car.
FORMERLY R240NA
Old 01-26-2009, 11:22 PM   #8
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
lol at this thread. i smell deep fried fail fries.
Marcus is offline   Reply With Quote
Old 01-27-2009, 02:07 PM   #9
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Id suggest ditching the Rear STB anyway and getting a set of solid subframe bushings instead.
Bigsyke is offline   Reply With Quote
Old 01-27-2009, 02:09 PM   #10
projectRDM
projectRDM's Avatar
Why? the STB does it's job well for the chassis. The subframe is a completely independent part, benefiting from it's own upgrades.
FORMERLY R240NA
Old 01-27-2009, 02:24 PM   #11
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
id like to see how you trimmed the cover on the upper part for the s14. i have the carbing rear bar for above and have just ditched the speaker cover because it wouldn't fit below
bigOdom1 is offline   Reply With Quote
Old 01-27-2009, 02:33 PM   #12
PITCH
PITCH's Avatar
PITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to behold
Mine was reversed. You had to cut the wall of the shock tower to mount it this way.
PITCH is offline   Reply With Quote
Old 01-27-2009, 02:37 PM   #13
deuceforty
deuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of light
i would never EVER cut the wall of the shock tower just to mount a bar...
thats idiotic
TWO TONE COUPE FS NC
deuceforty is offline   Reply With Quote
Old 01-27-2009, 02:41 PM   #14
projectRDM
projectRDM's Avatar
The Nismo bar comes with plates to cover the holes once cut, they're square with slots for the endplates to come through and then screw to the deck with small screws. You could easily duplicate them with a piece of sheetmetal or even ABS plastic.
FORMERLY R240NA
Old 01-27-2009, 03:44 PM   #15
bkfill
bkfill is an unknown quantity at this point
i didnt have to cut anything in my s14 to install cusco rear strut bar
mine gos under the hatshelf(rear deck)
if it aint broken, fix it(95 240/96 sr20)
bkfill is offline   Reply With Quote
Old 01-27-2009, 04:27 PM   #16
projectRDM
projectRDM's Avatar
All Cuscos do, as well as 99% of the knockoffs found online. The Nismo, Avanche, and Carbing go over the deck.
FORMERLY R240NA
Old 01-28-2009, 07:36 PM   #17
((sr)) kelly
ohhhhhhhhhhhhhhhhhhhh damnit!
i wanted to install the cusco 3 pt rear sturt bar out of my s13 into my kouki but looks like thats not going to happen.. fack!
ill just sell it and get a strut bar thats actually for a s14
Old 01-28-2009, 08:22 PM   #18
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
The JIC MAGIC rear strut bar goes over as well, which is what I have. I don't see what is so difficult about installing a strut bar.
garagelu is offline   Reply With Quote
Old 01-28-2009, 08:52 PM   #19
hunter8411
hunter8411's Avatar
hunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond repute
Send a message via AIM to hunter8411
I installed a Tanabe rear strut bar that goes over a while ago. I cut the speaker cover because I still wanted to keep it in there. Here are some quick pics of how I have mine.
I guess there are 2 types of speaker covers, one with the BIG metal speaker covers, and the one with the small metal speaker covers, I had the BIG one.
I ended up measuring and cutting holes in the metal covers with a dremel, then bought some leather from a crafts store and cut then hot glued it to the cover. I like the outcome, even though I am not fond of the red strut bar.
hunter8411 is offline   Reply With Quote
Old 01-28-2009, 09:19 PM   #20
unlegendary
unlegendary is a well-known jackass
so you had to embarrass your home boy for asking a dumb question FOR YOU? what kind of friend are you?
Full Time Student for Life
unlegendary is offline   Reply With Quote
Old 01-28-2009, 10:32 PM   #21
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Another option would be to weld the two strut towers straight to each other.
g6civcx is offline   Reply With Quote
Old 01-29-2009, 09:28 AM   #22
projectRDM
projectRDM's Avatar
Zenki base models and all Kouki models have the small, round plastic grilles, Zenki SEs got the larger metal grilles. I took my speakers out of the rear deck, moved them to the quarter panels, and bought a base deck cover without speaker holes for a cleaner look. I then wrapped it in black vinyl, looks better and easier to clean that that carpet they use.
You can always powdercoat the bar another color. Red would bother me too.
FORMERLY R240NA
Old 01-29-2009, 01:10 PM   #23
chuonthis
chuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the rough
FYI, I think this isn't posted in many places but the Greddy bar goes under the deck like the Cusco ones. Greddy 14023010 GREX Triple Tube Rear Strut Tower Bar S14
chuonthis is offline   Reply With Quote
Old 01-30-2009, 02:40 PM   #24
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
I have the Greddy bar and it goes under the rear deck which I like. The above the deck ones do not look that great IMHO. Of note, I did not feel a huge difference with the rear bar, make sure that you get the rear subframe spacers too, I felt more difference with those.
Colorado S14 is offline   Reply With Quote
Old 02-07-2009, 01:22 PM   #25
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
Is anyone using Tein's strut bars on the s14???
I was thinking of using a DC sports front on my car, and tein rear. I like the RC sport because it is solid weld. Goot knock off of the ARC. Holla!
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 02-07-2009, 01:48 PM   #26
neverrain
neverrain's Avatar
neverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud of
-Bart
I use the Tein Front and Rear on my s13 and they are fantastic. Quality is good.
I'm not really sure if this is a quality question or a specific s14 bar question though.
neverrain is offline   Reply With Quote
Old 02-08-2009, 01:06 PM   #27
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
just out of curiosity, did anyone feel any difference with the nismo strut bar or similar types that go above the rear deck? I don't know many people that have a s14 and rock quality rear strut bars
Old 02-08-2009, 01:12 PM   #28
rb25crazy
rb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of light
i got a cusco that goes under the speakers. it's not a hard install, just kinda cumbersome b/c of the cramped spaces. also nothing has to be cut if you install the strutbar that goes under the speakers, mine came in 5 pieces, 2plates, 2 more plates and a bar. you just need to install each one at a time can;t just toss it all in at once like a front strut bar. honestly, i don't really notice anything different lol... i just like the look of it. then again i don't drive my car like i stole it. i don't have a rear sway bar, but i do notice that when i turn harder the car goes back to a level position faster. but, i have coilovers now as well, so i can't say if it's b/c of the coils or a combo of coil n strut bar.
rb25crazy is offline   Reply With Quote
Old 03-13-2012, 07:38 PM   #29
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
anyone install the ebay ones? im having a hard time fitting the brackets into the holes.
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 03-13-2012, 07:45 PM   #30
slydin240sx
slydin240sx is an unknown quantity at this point
-Bart
I have a Tein rear strut bar on my s14. I like it a lot!!
Well that's your problem, it's eBay garbage!
slydin240sx is offline   Reply With Quote
