Peakboost SR20 manifold setup. SOLD
Had this on a redtop in an s14 chassis and fitment was great, but no room for a/c lines near firewall. Clears P/S perfectly. Most of this was heat wrapped, which I took off. Includes: - T3 manifold (great welds, no cracks) w/ 38mm WG flange - 3" 4 bolt upper downpipe w/ o2 bung (welded the egt bung shut and has some slag on the side from it) - 3" v-band upper downpipe w/ o2 and egt bung - v-band lower downpipe w/ cat delete and wideband bung (connects to the upper downpipe via v-band and deletes the cat to connect directly to catback exhaust) - wastegate dumptube w/ flexible pipe - 2 x v-band clamps and 1 gasket Tial 38mm wastegate w/ 10lb spring. Has a bit of scratches, but works great. - SOLD GT3071 .63AR T3 turbo - SOLD - Less than 50 miles on it. Barely had time to drive on it so didn't push it at all. - No play and spins freely - Hose barb tapped on compressor housing for boost controller - Includes .035" restrictor, gaskets, and -10 oil drain flange(lost gasket for this) Last edited by Thaiair; 04-13-2014 at 03:51 PM.. |
So tempting
