![]() Join Date: Jan 2002
![]() ![]() ![]() Feedback Score: 1 reviews
yeah... somebody posted that you could unplug the tranny sensor so that it would shift faster....
i tried it.... didn't like it, seemed to shift harder... not faster i turned the car off, and started it again, and missed the code now my tranny light is on (with the thingy plugged back in) i disconnected my battery for about 30 minutes still there any ideas? TIA Sean (i know i am a stupid bastard, but i had to try it)
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage 95 base - retired |
I hate you too...
![]() Join Date: Jul 2001
There are 2 courses of action here.
1) Look on this page, or one back, and find a post along the lines of "Dumb question... resetting ECU." And reset the ecu. Or 2) Turn your car on and off 100 times through the course of normal driving, and your code will shut off. It took me about 3 weeks. -Jeff
Whatup? |
![]() Join Date: Nov 2001
Hey ok what year do you have for one,Seconf got to 240sx.org and go to facts and located resteting ecu if you have a sohc got to that so on its not hard.Take about 10-20 minutes to get done right.
Will never get banned...
![]() Join Date: Sep 2001
![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (negular @ May 01 2002,10:04)</td></tr><tr><td id="QUOTE">i thought upluggin the battery for a little while, would reset the ecu</td></tr></table><span id='postcolor'>
nissans ecus has a back up memory it will rember what and when the code was tripped what mileage you were doing rpm your a/f ratio and more. so 30 minutes is not enough ram and rom <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=' '> listen to what jeff said about resetting the ecu, but i have never heard the 100 times+ on off scenario nor do i think that will work. that will not resolve the problem the ecus memory will still be there
-=-99 Sentra SE 5 speed-=- -=-95 240 SE 5 speed-=- |
sorry to bring this back from the grave, but i went over to teh [email protected] 240SX.org... it tells u how to run a diagnostic... which i did
i got 125? 12 slow flashes 5 quick ones [edit]n/m i figured it out.. i was being dense[/edit]
