Leaking water pump?? Ka s14
I just realized the other day only when my car is on it will drip water out of the engine somewhere, it's not a hose it just drips off the bottom of the engine and once I turn it off the dripping stops. Could this be a water pump? I can't really see with everything on my car from where it's leaking from inside the engine bay. But on the ground it is water so if anyone has any ideas thanks. I do believe it is the water pump just want to be sure
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Is it straight water? Is your A/C running? If so, the A/C evap box has a drain located on the passenger side. My car leaves a sizeable puddle when I shut off the car.
No with the ac off and everything when it's running it drops and then when I turn it off it will drop for a minute or two then it will stop
| leaking 240 s14 wayerpump |
