Closed Thread
Old 09-13-2011, 12:30 AM   #1
Knapik
Knapik's Avatar
Trader Rating: (36)
Knapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to all
Feedback Score: 36 reviews
Cleaning out Garage! SR/KA/S13/S14 SELL IT ALL!!
Hey guys,
ive got a LOT of parts for sale.
all parts are located in Westminster CA 92683
Email: [email protected]
S14 SE Front and Rear Sway Bars: $20 each
Ichiba Straight pipe: SOLD
S14 power steering rack: $60
S14 5 Speed non abs drive shaft: SOLD
S14 KA down pipe: $25
S14 brake booster: $10
S14 cruise control cable: $10
S14 SR cast iron turbo manifold: $50
S14 throttle pedal: $10
S14 driver side interior handle: $15
S14 passenger airbag: $40
S14 oem tie rods: $20
S14 oem tension rods: $20
S14 axels: $50 each
S14 A/C pump: SOLD
Random pullies: $5 each
S14 KA heat shield: $10
T25 turbine w/ no shaft play: SOLD
S14 A/C core: $20
S14 windows with no cracks: $30 each
Brand New S14 SR valve cover: $80
S14 steering wheel: $10
S14 steering wheel air bag: $20
S14 Silver Moss gas tank door: $10
Brand new SR OEM oil pan (installed, then taken off the next day on an engine that was on an engine stand): SOLD
S14 ebrake cables: $40
s14 windshield wiper motor: $10
S14 tension rod brackets: $30
S14 SR lower intake manifold: $30
S13 Speed sensor: $50
SR Crank Angle Sensor (CAS): $50
S14 SR idle air control vavle: $30
S14 power window motors and rails: $30 each (only passenger side left)
S14 SR fuel rail with injectors: $80
KA engine to manual trans mounts: $30 each
S14 manual trans mount: $20
S14 hood hinges: $20
power steering banjos: $10 each
SR power steering pump bracket: $40
SR alternator bracket: $40
S14 hood latch: $15
power steering res: $10
Touge Factory SR hot pipe: $25
Factory cat: $20
S14 SR bottom end: SOLD
S14 front crossmember: $40
S14 open diff: SOLD
S14 Block: $200 each
S14 SR head with valves: $200
S14 SR second oil pan: $50
SR engine to trans sandwich plate: $30
S14 SR crank: $50
SR starter: $50
GReddy Speed Limiter Cut: $40
4x6 H4 Conversion: $20
AE86 Zenki Driver side tail light: $40
S14 rear JIC Magic Strut Bar: SOLD
SR Engine Bracket: $50 per pair
If you see something pictured that isnt listed just shoot me a price of a pm to ask and ill be happy to work with you.
thanks
adam k
Link to pictures because there are over 150....soooooo enjoy haha
garage sale pictures by knapikpb - Photobucket
not anti-drift, just pro-grip
Knapik is offline
Old 09-15-2011, 02:13 AM   #2
LegitSeller
LegitSeller's Avatar
LegitSeller is an unknown quantity at this point
pmed about driveshaft
LegitSeller is offline
Old 09-15-2011, 08:31 PM   #3
Nick Thorp
Nick Thorp is an unknown quantity at this point
pm sent for brake booster
Nick Thorp is offline
Old 09-15-2011, 10:45 PM   #4
akito
akito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of lightakito is a glorious beacon of light
Will take thecrossmemberand driveshaft if other guy doesnt get it.
akito is offline
Old 09-15-2011, 11:00 PM   #5
seeks14
seeks14's Avatar
seeks14 is an unknown quantity at this point
S14 driver window switch n.radio trim. By aany.chance???
JDM-FIEND.COM
ASE cert.
seeks14 is offline
Old 09-15-2011, 11:28 PM   #6
Knapik
Knapik's Avatar
Trader Rating: (36)
pms replied.
still have the cross member but the drive shaft is spoken for for now. please let me know when you want to meet up for the crossmember
714-376-5623 call and text is fine anytime
thanks
adam k
Knapik is offline
Old 09-16-2011, 05:53 PM   #7
Knapik
Knapik's Avatar
Trader Rating: (36)
sorry no go on either of those
Knapik is offline
Old 09-16-2011, 07:04 PM   #8
justin35ll
justin35ll's Avatar
justin35ll is an unknown quantity at this point
Send a message via AIM to justin35ll
s14 front lower control arms?
trade me your coupe for my hatch
justin35ll is offline
Old 09-16-2011, 07:29 PM   #9
Knapik
Knapik's Avatar
Trader Rating: (36)
i have the front right with no ball joint. let me know if you are still interested
Knapik is offline
Old 09-16-2011, 10:04 PM   #10
illvialuver
illvialuver's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
I need that hood latch if it is in working condition. Thanks, call me.
no homo
illvialuver is offline
Old 09-17-2011, 09:00 AM   #11
ultramagnus
ultramagnus's Avatar
Trader Rating: (41)
ultramagnus is an unknown quantity at this point
Feedback Score: 41 reviews
How much do you want for the hub ? will it fit s13 and are the bolts complete? just PM me i'm in OC too.
http://i1141.photobucket.com/albums/...agesale104.jpg
"Consistency is Victory"
ultramagnus is offline
Old 09-18-2011, 01:28 PM   #12
Knapik
Knapik's Avatar
Trader Rating: (36)
no homo
Hood latch is in working condition but I don't have your #
So here's mine 714-376-5623. Call or text is fine
Thanks
Adam k
Knapik is offline
Old 09-18-2011, 03:55 PM   #13
Jerrys14q
Jerrys14q's Avatar
Jerrys14q will become famous soon enoughJerrys14q will become famous soon enoughJerrys14q will become famous soon enoughJerrys14q will become famous soon enoughJerrys14q will become famous soon enough
Send a message via AIM to Jerrys14q
still got it
Jerrys14q is offline
Old 09-18-2011, 05:20 PM   #14
Knapik
Knapik's Avatar
Trader Rating: (36)
still got it
Yup still got it
Knapik is offline
Old 09-18-2011, 05:39 PM   #15
Jake1992
Jake1992's Avatar
Jake1992 is an unknown quantity at this point
is your car RHD ? is your rack leaking ??
Jake1992 is offline
Old 09-18-2011, 08:20 PM   #16
Knapik
Knapik's Avatar
Trader Rating: (36)
Car is LHD and the rack is not leaking
Knapik is offline
Old 09-20-2011, 09:00 PM   #17
Knapik
Knapik's Avatar
Trader Rating: (36)
all pm's replied
Knapik is offline
Old 09-23-2011, 12:51 PM   #18
Knapik
Knapik's Avatar
Trader Rating: (36)
bump.......
Knapik is offline
Old 09-23-2011, 10:08 PM   #19
Future240
Future240's Avatar
Originally Posted by Knapik View Post
pms replied.
thanks
adam k
Thanks
Adam k
Yup still got it
all pm's replied
bump.......
Over the 2 bump limit, you can start a new thread in 3 days.
#/rules.html
Thread Bumping
You may only bump your thread TWICE. That is not 2 times a day, or two times a week. TWICE only.
A bump is constituted as any unnecessary post you make in your sale thread. This can include:
“Bump”
“To the top”
“All Pms Responded to”
“Price Drop”
Etc, etc, etc
You should utilize the PM system to answer potential buyer's questions, and you can edit your initial post to reflect any detail updates, or price changes.
Originally Posted by ThatGuy
Future240 is online now
Closed Thread
