Hello people I sent a question on the position of #1 cylinder as it looks without head, doing a head gasket now on KA24E and turned crankshaft couple of times to clean cylinders and oil cylinder walls. I just want to confirm that # 1 cylinder should be at vert top of engine block
:2f2f |
Every cylinder has a "TDC". Piston at the top of it's stroke, as high as it can go.
TDC#1 is just that... on the first cylinder...
Current Crazy: KA with SR56 and meth injection for HDPE and steet duty |
Thank you so much that makes total sense, very easy in those terms I've had to pull my top end off ( water issue) so we did head gasket checked everything, oil not grey or foamy hopefully it's not my front cover ! You can still get those new if you want on a KA24E SOHC THANKS AGAIN
:2f2f |
| please help |
