stuff you may need and rb25 conversion mounts
ok guys i have some stuff that is just in the way in my garage and maybe some of you need this stuff everything list is in good working order unless listed otherwise.
craftsman 4 ton low profile jack $100 Used rb25det timing belt tensioner and idler pulleys $25 New sr20det timing chain $60 New oem sr20det H/g $50 S13 front fenders good condition need paint $50 for both B magic 50mm rear over fenders for hatch driver side is brand new passenger side is cracked can be repaired $75 pending 3000gt aluminum radiator $50 VW scirocco aluminum raditor $50 Bnib sr20det god speed radiator $80 sold Wide band sensor $25 S13 crossmember w rb25det coversion mounts $175 stock rb25det exhaust mani $15 Big let silvia front grill all tabs are a ok $50 stock s13 hatch tail lights with everything $50 s14 ka upper plenum $15 stock rb25det throttle body $25 stock sr20det turbo dump with o2 sensor make offer stock rb25det turbo dump make offer complete stock s14 intake system with maf (will part) not all pieces pictured $70 s14 open diff $45 bnib tomei solid lifters for rb25det rb20det and vg30 $450 Hks turbo timer harness $old e60 maf with pigtail $30 2 5 spd sohc ecu $15 each S14 5 spd ecu sold everything listed is obo but i do feel that the prices are pretty low. the best way to reach me is by pm. thanks guys and gals here are the pics. Last edited by P-Funk alot; 12-04-2010 at 09:54 AM.. |
Where are you located @? Dibs on the hks turbo timer harness.
