240z front brake question ,
I just bought my 72 z and the brakes have an issue. The front brakes drag really bad sometimes. I think the calipers or proportioning valve might be bad. Is there anything else it might be ? Also are there any options for upgrading the brakes without spending a ton ? Thanks
![]() Join Date: Sep 2006
find yourself a 240z fsm online and make sure that everything is in spec.
as for the brake upgrade, do a google search. zilvia is more oriented for 240sxs, sign yourself up on some Z specific forums and read, search, read, search, and read some more before you ask any questions. most likely all your questions have been asked and answered 100 times over ![]()
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
Best thing to do is just get in there and see whats going on. You should change the brake fluid anyway. Take everything apart and polish it up and reinstall. I recommend Hybridz.org for anything S30...
1972 Datsun 240z that thinks its a Skyline.
