![]() Join Date: Oct 2008
Z32 bogging down, need help
Ive got a 1992 Nissan 300zx NA 5 speed. its got 128,xxx miles.
Here is one problem i was having... When i stop somewhere for about 5 minutes (like to a gas station or something) and come out to the car and start it, it will start, and immediatly die. Then it wont start for a few minutes and i have to give it full throttle. Then when it finally does start, it runs perfect. Here is the new problem... When is start the car it idles normally for about 5 seconds then boggs down to about 300 rpms and dies after a few seconds. If i start the car and give it gas and hold it 3000 rpms after about 3 seconds the car will bog down to about 2100 rpms while still giving the same amount of throttle. The car runs like shit right now. Ive changed the MAF because someone local told me to try that. I had an extra lying around so it was easy. Same problem still occurs. I assume its a fuel problem. I havent checked fuel pressure yet or spark but i recently changed all 6 coils with known working ones. Let me know if you have any ideas. Thanks, -dan |
im having the same problem -_-. im going try and clean the throttle body to see if that helps because like you said its a throttle problem, so maybe it just somehow clogged.
i might have solved the problem, but im not entirely sure.
i cleaned the throttle body( i found a ton of gunk and residue in there) to clear up the intake passage to the engine. i also tighten the throttle cable a slight bit so far car is running good with no bogging hopefully it will work for you
I'm having a bogging issue with my 300 aswell, however its under load. Id be pinning it at around 60-80km/h and it would get stuck at that speed and no matter how hard i give it throttle, it wont accellerate any further, happens intermittently, but very often. Any ideas? I was thinking maf for my case :S
Dan, if you're not already a member then you need to join 300ZXCLUB.com We have a section just for the Louisiana Z owners that has roughly 20 members. More than 1/2 are in your neck of the woods.
i also just started having this problem i cleaned the super dirty throttle bodies it runs better but the bogging still happens between 2500 rpm to about 3300 rpm please help.
DONT HATE MEH CUZ U AINT MEH!!!!
