Desmond WiseSport 17x7 +48 17x8 +48
I have for sale a set of Desmond Wise Sports wheels.
Asking $1,400 obo 17x7 +48 and 17x8 +48 They are in excellent condition, and include the original center caps and spoke gel decals. One wheel looks to have been rebuilt, as it has different color sealant, but all faces and lips look great. I purchased these with the intent of having them rebuilt wider, but soon found another set of wheels that I prefer more than these. Located in Southern California and unfortunately cannot ship. More photos available upon request. The specs are: 5x114.3 Front 17x7 +48 with 0.5 lip and 6 barrel (sandwich mounted) Rear 17x8 +48 with 1 lip and 6.5 barrel (sandwich mounted) Aftermarket 73.1mm hub bore so you can buy the correct hub rings. To clear larger brake calipers such as Z32, you will need a 15mm spacer. I have already done some calculations to see what new specs would be if new lips were purchased. For example: Front new 1.5 lips and the 15mm spacer make it 17x8 +20 Front new 2 lips and the 15mm spacer make it 17x8.5 +14 Front new 2.5 lips and the 15mm spacer make it 17x9 +8 Rear new 1.5 lips make it 17x8.5 +42 Rear new 2 lips make it 17x9 +35 Rear new 2.5 lips make it 17x9.5 +29 Rear new 3 lips make it 17x10 +23 Photos to be added in next post
1991 Z32 NA t-tops 5 speed 1997 S14 KA24 5 speed |
