Looking to sell my 1jz parts.
1jz non vvti to s13 wiring harness made by chase bays. Was over 1300 new would like sold Aem v1 ecu $sold Hks dli ignition system $350 Cx racing turbo kit (manifold, turbo, lines, wastegate and downpipe) this kit has under 100 miles on it $650.. little to no shaft play. Hits boost fine zero issues 1jz non vvti head without valve covers, turbo manifold/ turbo. Super mint. Zero marks on cams and valves look mint. Never overheated. With 440 injectors $450 1jz non vvti block with crankshaft, rods and pistons plus new rings in box $400 1jz non vvti 'blown' block with good crank and rods but pistons bad. $150. Cylinder 4 has wall damage needs to be bored over to fix. 1jz alternator $60 1jz front sump oil pan setup ( upper, lower, and pickup) $100 *** water pump and oil pump will not be Included** Located 20 min south of Chicago Illinois. Price is obo. Will accept trades as in running s chassis's or 3 piece wheels Also will ship at buyers expense. If you would like pictures please text 708 three four one 868one anytime
Using Tapatalk Last edited by frankscalise74; 03-03-2017 at 10:29 PM.. |
| 1jz, 1jzgte, 240sx, s13 |
