#151 |
@UpshiftEngineering |
#152 |
ahhh. damn. i was hoping that'd fix my car. lol. thanks for ur help tho. i can rule out one more thing.
#154 |
![]() Join Date: Jun 2003
this is supposed to be for small questions, not easy ones.
HICAS - Wikipedia, the free encyclopedia you won't find hicas on any coupe (at least USDM, i don't remember if it's the same everywhere).
#155 |
Hey guys im in a serious delema....
ill 350z track rotors the 12.5" ones with 30mm skyline calipers fit with mb battles 17x9.5+15? |
#156 |
![]() Join Date: Jun 2009
ok so i got a silvia hood emblem and it has the studs for the pre drilled holes on the oem hoods but i have a carbon fiber hood
so should i just break off the studs and put it on or drill 2 small hoods in my hood?
#157 | |
sdazd |
#158 |
alright i been thinking..im not too sure about this but am wondering if nissan"s steering wheels are interchageable like..for example..i want to switch my 95 s14 steering wheel to a 97 maxima steering wheel..Will it be plug and play..like especially the treaded pitch..or what ever..just want to know if its plug and play before i go off and buy one..and end up not fitting like it should..thanks
#159 |
anybody know how to remove the "240sx" emblem off the the rear trunk panel? the "best way" not the ghetto scratch the fuck out of my rear end way. floss, credit card.. anything?
#160 |
I got some stuff at autozone called sticker off or something like that.. It worked pretty well.. Just don't leave it on your bumper too long (like forgetting to remove it..) or it will make it look foggy.. Floss and a blow dryer or heat gun at low temp should work fine.. Then use some scratch x to finish it off..
#164 |
![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
so my ka finally took a dump and looking for a s14 sr does any body know a shop or online website that has at least a 30 day start up warranty if the motor does not work. just want to get a good sr that will last me
#165 |
I dont' know about the 30 day start up warranty, but I had my car swap done at Sr20store. Marco (i think that's his name) very nice guy. After the swap about a 3 days later I had problems starting the car wouldn't turnover. I called Marco and he said ok and DROVE to my house and fixed my car no charge.
He's a bit expensive but well worth it IMO. |
#166 |
#167 | |
![]() Join Date: Jul 2007
should be. i'm in the process of putting in a JDM S14 kouki to replace my USDM, here's the write up: Putting a 200sx/Silvia/R33 steering wheel in an s14 240sx: 240SX Forum / 180SX Forum / Silvia Forum: Nissan Forums / Infiniti Forums - NICOclub on the bottom, they say the Maxima wheel is actually very similar. |
#168 | |||
you talking about the GTR brembos or the sumitomo 4 pots like the z32? in either case you'll probably have to find someone with the same setup or start measuring.
#171 | |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
do you see blue smoke out the exhaust at startup or driving?
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#172 | |
d21 pickup, maybe? search "white bunny clutch" on ka-t.org, if you are looking to upgrade. its a popular choice with the dohc's not sure about sohc interchangeability.
BRICKHOUSE PRODUCTS
#173 |
what does this harness do? I cannot locate it in fsm. It is located on the passenger side under the carpet (97 240sx). I think it the connection for radio or lights? Can someone confirm? |
#174 |
![]() Join Date: Sep 2007
i just did a little search on the 180sx vlsd. thats a straight forward bolt on, i have a different cover on mine than the 180sx. so it would have to be something else
#175 |
people! this isn't the identify this thread!! some questions here could have been asked there!!! what are these, who makes these, what brand/company are "identify this" thread material!
#176 | |
![]() Join Date: May 2004
Trader Rating: (26)
so who knows what flywheels are interchangeable for the KA24E? for instance: will an sr20 flywheel work with ka24e? will a ka24de flywheel work with ka24e? if not, are there any other flywheels that will work with ka24e? |
#178 | |
Trader Rating: (26)
KA24DEvelopment.com :: VLSD Swap Information |
#179 | |
Ah, bummer. Thank you for the info though. |
#180 |
Bandwagon.
just add a resonator?
not the box ones but the tubed ones. |
| 180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
