Old 03-14-2018, 09:43 AM   #1
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
Diff removal
Ok so this is a noob mistake. I removed the subframe without disconnecting diff/axles/driveshaft or 5 lug hubs. I figured it would be easier if the subframe was on the ground. The problem is diff is spinning now since there is no ebrake applied. How can I remove the axles/diff/drive shaft/5 lug hub? Any way to make the diff not spin?
dreaMervaj is offline   Reply With Quote
Old 03-14-2018, 09:50 AM   #2
afishysilvia
afishysilvia's Avatar
Trader Rating: (30)
Feedback Score: 30 reviews
As far as driveshaft and axles flanges to diff, use double wrenches to remove the hardware.
Axle nuts: Impact gun, only way now.
afishysilvia is online now   Reply With Quote
Old 03-14-2018, 10:00 AM   #3
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Put two nuts with bolts on the driveshaft flange of the diff and have a buddy hold a pry bar between them to stop spinning while you loosen everything.
[email protected]
hanzbrady is offline   Reply With Quote
Old 03-14-2018, 11:35 AM   #4
TheRealSy90
TheRealSy90's Avatar
Or stick a pry bar in the lug studs so that it pushes against the ground. Use that noggin.
Such a good signature.
