(fs) s14 partout
PM me your number and ill send you picture of whatever you need to see!
Yes, I will ship anything as long as you cover it. (2)H&R 15mm 5 lug slip on spacers - $100 (2)H&R 25mm 5 lug spacers - $120 SR Nismo thermostat (New) - $100 S14 OEM steering wheel - $50 S14 5 lug drilled rotors - $20 S14 airbags - $80 S14 catalytic converter and exhaust piping - $50 S14 clock spring - $25 S14 hood latch - $30 S14 96' ECU - $100 S14 kouki Passenger headlight (spyder black housing) - $100 s14 OEM RUCAs - $30 S14 SE wing - $40 s14 Silkroad RUCAs - $150 s14 SR IACV - $40 S14 to z32 MAF connecter - $20 S14 Windshield washer fluid reservoir - $20 S14 Working condition OEM fuel pump - $20 |
| nismo, oem, rear upper control arms, s14, spacers |
