I will ship everything unless mentioned otherwise. Paypal payments + 3%. If there's a picture up, I still have it.
I've got a garage full of s13 coupe and hatch parts that need to go! I don't have much room for my build, and winter's coming. Here's what I've got! T25 Garrett Turbo: Some back and forth journal bearing shaft play, no in and out, should still be good. $100 shipped CA18DET AC compressor (working) and bracket w/tension adjuster. $80 shipped (it's heavy!) KA/SR/CA transmission mount. Good rubber. $25 shipped OEM CA18DET exhaust/turbo manifold. Good shape, no gaskets. $50 shipped. S13 stock fuel pump and assembly (untested, but believe it's working): $50 shipped s13 main wiring harness converted for KA24DE. It was working in the car, and nothing was damaged when it was removed. However, it was modified by someone else, so I do not know anything else about it, other than it was working. $50 shipped '89 Coupe weather stripping. Good shape, had no leaks while in the car, no tears. Both doors + trunk. $40 shipped Coupe tail lights. Excellent shape, no cracks. $75 shipped Rear 3rd brake light. $50 shipped Door, Passenger, automatic, with glass. Good shape, strong motor. $50 (will not ship) OEM hood. Maroon (needs to be re-cleared). $50 (will not ship) AC Compressor, all lines, condenser, evaporator, drier... the entire AC system. That's right... bask in your cool comfort in the summer, and actually defrost your windows in the winter! Working and no leaks when it was still running. $275 shipped for the whole shebang! (I'd rather not part it out at this time) ***PRICE DROPPED*** Individual AC lines, drier, and condenser (not part of the "complete" system listed above): Tell me what you want in the following picture and I'll send you a price. S13 KA24DE OEM Electric Fan (excellent condition): $75 shipped Exhaust/Pipe Extensions (Stainless, originally for mounting a 350z exhaust to a G35, can be used for anything though): $40 shipped Blower Motor + airbox: $50 shipped Heater Core (no leaks, works good) + Airbox: $60 shipped Fan blower speed resistor: $20 shipped AC/Heater control panel: $20 shipped Stack of 4 Infiniti Q45 front rotors. All good shape and thickness (but have surface rust from sitting in my garage): $10 each or $30 for all 4. (will not ship) Jensen 400 watt (100x4) Amp. Bridgeable (2, 3, or 4 channel), 2 inputs, 2 pass-throughs, and built in bass boost and cross-overs. A little oldschool but worked well in my last car! $60 shipped. S13 front inner fenders. Good condition, slight wear on one side but will mount up, hold, and cover your inner fender and wiring great! $30 shipped Fuel Tank + Sending unit/Pump + Filler neck. Good shape. $60 (will not ship) Full KA24DE un-cut upper wiring harness. $100 shipped. Auto ECU. $40 shipped Auto Radiator (KA/CA). $20 (will not ship) KA Igniter: $25 shipped Shark Nose with corner lights: $80 (will not ship) Full 93 Coupe seat belts (not including automatic motors and rails, a few pieces included but not pictured). $30 shipped. Get them before Friday... or they go in the trash! Excellent condition Nintendo Gamecube with 1 wired controller (works also on the Wii), 2 "wave-bird" wireless controllers, mic, memory stick, and all cables/cords. Plus! a full stack of Gamecube games (that still work in the Nintendo Wii!!!) including Zelda Ocarina of Time (and Ocarina of Time Master Quest), Super Smash Brothers Melee, Metroid Prime, Metroid Prime 2: Echoes, Mario Party 7, Final Fantasy Crystal Chronicles, Sonic Mega Collection (7 classic sega-era sonic titles), Sonic 2 Battle, and Super Mario Sunshine! $70 shipped
'08 350z Grand Touring - DD '89/92/93 240sx Coupe - "Frankenstein" project Last edited by Lrn2Go; 12-20-2011 at 10:09 AM.. |
I do! $50 Shipped. It's in excellent shape. I can get you a picture if you need it!
'08 350z Grand Touring - DD '89/92/93 240sx Coupe - "Frankenstein" project |
#6 | |
$25 shipped.
Best picture ever!
![]() $20 shipped and it's on it's way!
Will the p/w amp work for the hatch as well? If possible, im interested in pics of the side marker to make sure the clips are intact. Also do you have a pignose lip?
#10 | |
I do not have a pignose lip. The p/w amp works for the hatch and the coupe (s13). Here's some pictures of the side markers. One of them is broken where the plug attaches (could easily be superglued where you couldn't tell, but I decided to take the picture without it), but it doesn't effect how it looks, nor how it fastens into the car. All "mounting" tabs are still in place and in good condition.
#13 | |
PM'd you back. Also... back in the United States! Sorry about the lag in responses. The parts list has been updated. Thanks!
#17 |
I've added a T25, transmission mount, and exhaust manifold to my list.
#19 |
Sure! I'll add them tonight. Was there something in particular you wanted to see?
#20 |
#23 |
I'm near Oklahoma City. Anything I can do for ya?
PM'd
'08 350z Grand Touring - DD '89/92/93 240sx Coupe - "Frankenstein" project Last edited by Lrn2Go; 11-24-2011 at 09:15 AM.. |
#24 |
Here ya go! Let me know if you need anything else!
#26 |
how do you mean "key hole"? On the coupe trunk, you can take out the lock cylinder, but the hole is part of the trunk metal. Did you mean cut it out?
#28 |
I do not have a key for the lock any more, and I have someone picking up the trunk locally. If I didn't have to damage the trunk, and you didn't need a key, I'd be willing. But as such, I'll have to pass. Sorry!
#29 |
MAF, Trunk, Drivers Door, and Headlights sold... thanks! Added inner fenders.
| 240sx, coupe, s13 |
