![]() Join Date: Jun 2004
Trader Rating: (73)
Trust DD exhaust gasket replacement?
Just wondering if anyone else in here has ever replaced the turbo back exhaust TRUST DD gaskets?
The exhaust is on my car right now and it uses a standard 3" 2 bolt to the cat/test pipe. My question is, does anyone know what size goes to the dual pipes coming out of the resonator? I think they're 2" but they could be 2.25" Just thought I'd ask instead of taking it off and going to the parts store. I'll update the thread once I find out.
Trader Rating: (73)
Update found gaskets that worked.
Felpro 60899 As for bolts I would recommend a MINIMUM of 30mm long bolts if not longer no longer than 40mm tho. Because you want to use lock washers. Aside from that very happy with the install. I hope someone else can use this information. Cheers.
thanks for the info dude. even tho 90% of the dudes with an s chassis today dont know what this exhaust even is. other O.G's might find this useful.
thanks for keeping it 100 O.G |
#4 | |
