![]() Join Date: Oct 2006
Trader Rating: (163)
New and Used Built Motor Parts, Nissan, Tomei, CP, Apexi, Koyo, Greddy, Clevite
Please give me a zip code if you would like a shipping quote. I'm always willing to make you a deal on multiple items... just let me know what you want.
BNIB CP Forged Pistons SC7325 86.5mm 9:1: $449 ![]() ![]() ![]() BNIB Tomei 13024R310 Adjustable Camshaft Gear: $135 SOLD!!!!! BNIB 8 OEM Nissan 13234-53J01 Lifters/Pivot Rockers: $199 ![]() BNIB OEM NIssan 13257-53J03 Rocker Arms: $189 ![]() BNIB RP Sports SR20 Digital Valve Shim Tool: $145 SOLD!!!!! ![]() BNIB OEM Nissan S14/S15 Full Gasket Kit: $129 ![]() BNIB Clevite TW-590S Thrust Washer Set: $44 BNIB Clevite CB-1629 P-.25mm Rod Bearing Set: $44 ![]() BNIB Clevite MS-2015P-.25mm Main Bearing Set: $50 BNIB Wiring Specialties S15 SR - S13 Chassis upper and lower harness: $255 NOTE: A few pin swaps and this will work for the S14 SR also. ![]() ![]() Stock S15 SR20DET Parts: Make offer unless noted
![]() ![]() S13 Greddy V-Spec, Core Only: $400 Polished Golden Eagle Vacuum Box: $29 SOLD!!!!! (Earls fittings and/or lines are extra. Contact me if you want to discuss it) ![]() Unknown Stainless Downpipe: $80 SOLD!!!!![/SIZE] ![]() S13 Apexi GT-Spec Exhaust: $250 SOLD!!!!! ![]() Unknown Steel Driveshaft for 6-speed into S13 chassis: $100 Koyo Radiator for S13 SR: $150 ![]() Last edited by Broadfield; 10-17-2011 at 09:19 AM.. |
ill tongue punch her fart box
![]() Join Date: Sep 2009
hmmmm youre in il too. i might be after that exhaust next weekend.
ill shoot you a pm. if you have it next weekend id love to come grab it. |
Technically it is for an S13. S13 cams were going to be used in the S15 head and ditch the variable valve timing. There is only one because Mazworx is about the only shop that can truly tune dual adjustable cam gears on an SR.... and they are about a 1000 miles from Illinois. If you need two then you could simply buy a new one and this one.
#20 | |
I only have what is listed. |
| cp pistons, greddy, koyo, nissan, tomei |
