need help with z32 brake on s13 set up
i have a s13 but I'm trying to run a z32 brake set up on it
parts i have enjuku 5 lug conversion 300zx front and rear calipers my question is can i run z32 on front and rear with the e brake? or should i just run z32 front and 240 rear calipers? if i can run the z32 brake calipers what rotors should i run to fit my s13 with the z32 calipers? lastly if its easier if someone can tell me what parts am i missing besides pads to complete the swap thanks |
![]() Join Date: Jun 2010
To complete your brake swap you will need the following parts from a Z32: rotors front (26 or 30mm) and rear, brake master cylinder, conversion brake lines front and rear, parking brake assembly, cables and brackets.
I suggest you do some more research as it seems like you don't know what you're getting yourself into. Z brakes on an S-chassis has been done thousands of times. All of the required info is out there. |
| s13, z32 |
