Please text for quickest response 206.658.36 seven eight
Suspension/Brakes BNIB S13 Control Arms - $60/pair Used S13 Control arms -$30/pair S13 LCA with Villains 40mm Extensions - $ 60/pair Driver side S13 LCA - $10 S13 Knuckles without calipers - $60 S13 Knuckles with calipers - $80 S13 Tension Rod Brackets - $60 RHD S13 Steering Rack w/pump - SOLD RHD S13 steering Rack - SOLD LHD S13 Steering Rack (needs new hard lines) - $60 S13 Solid steering spacer - $10 S13 Rear Calipers w/e brake cables - $80 S13 Front calipers - $60/pair S13 Passenger Side Front caliper - $20 S13 Rear Calipers (no provisions for stock e brake) - $40/pair S13/S14 rear caliper parts box - $20 S13 handbrake cables - $40/pr S13 handbrake handle - $20 S13 welded diff (whines a bit) - $40 S13 diff cover (pictured on S14 diff) - $10 Z33 (350z) Handbrake cables - $40 S14 Control arms - $80/pair Passenger side S14 control arm - $20 S14 New Single front 5 lug hub - $60 S14 Single rear 5 lug hub - $60 S14 Knuckles - $100 S14 Tension Rod Brackets - $80 S14 Front Crossmember - $80 S14 5 Speed Non-ABS Driveshaft - $60 S14 Brake Booster with master cylinder - $60 S14/S13 rear caliper parts box - $20 S14 handbrake cables w/mounting brackets - $60 S14 welded diff - SOLD S14 handbrake handle -$20 Interior S13 dash with all underdash parts, dashbox and bezels (non A/C) - $180 RHD S13 dash (also have all underdash parts with A/C stuff) - $180 S13 window amp - $20 S13 hatch trunk release w/cable - $40 Complete S13 hatch chassis harness (underdash and interior) - $200 S14 Dash - $80 S14 driver side window switch w/bezel - $40 S14 passenger side door handle (no window switch) - $free S14 underdash harness (not sure if kouki or zenki)- $60 Kouki S14 wiper/light switch - $20 Engine S13 SR20DET coil pack harness w/coils - $80 S13 throttle cable - $20 S13 KA24DE distributor - $60 S13 alternator bracket (not sure if KA or SR) - $20/ea S13 SR water neck - $20 (can weld fitting on for addl $20) KA/SR throwout bearing w/sleeve- $20 KA/SR clutch fork - $20 SR coil pack - $5ea S13 SR stock flywheel - $20 S13 SOHC power steering reservoir- $5 S13 DOHC power steering reservoir -$10 Apexi BOV - $10 S13 DOHC KA engine harness - $40 S14 throttle cable - $20 S14 KA24DE distributor - $60 S14 KA valve cover - $20 S14 SR oil pan with rear main seal plate - $60 S14 SR rust free Turbo manifold w/heatshield - SOLD S14 fuel pump w/sender - $20 S14 SR (no rods/pistons,no valve cover, no turbo- head is toast-comes with many extras) -$200 STI 550cc injectors w/adapter harness - SOLD Exterior S13 Door hinges - $20 S13 hood latch - $20 S13 hatch trunk latch (chassis side)- $20 S14 Driver side Door w/glass (no window regulator) - $60 S14 door glass - $40/pair S14 trunk latch (chassis side) - $20 18x9 +40 SSR Type C (very light!) *5x120* - $200/pr ![]() 20180514_195136 by BigChance, on Flickr ![]() 20180514_195133 by BigChance, on Flickr ![]() 20180514_195131 by BigChance, on Flickr ![]() 20180514_195126 by BigChance, on Flickr ![]() 20180514_195120 by BigChance, on Flickr ![]() 20160920_212456 by BigChance, on Flickr ![]() 20180522_182057 by BigChance, on Flickr ![]() 20180522_182053 by BigChance, on Flickr ![]() 20180522_182002 by BigChance, on Flickr ![]() 20180522_181651 by BigChance, on Flickr ![]() 20180522_181647 by BigChance, on Flickr ![]() 20180522_181643 by BigChance, on Flickr ![]() 20180522_181634 by BigChance, on Flickr ![]() 20180522_180917 by BigChance, on Flickr ![]() 20180522_180908 by BigChance, on Flickr ![]() 20180522_180850 by BigChance, on Flickr ![]() 20180522_180844 by BigChance, on Flickr ![]() 20180522_180841 by BigChance, on Flickr ![]() 20180522_180837 by BigChance, on Flickr ![]() 20180522_180833 by BigChance, on Flickr ![]() 20180522_180817 by BigChance, on Flickr ![]() 20180522_180808 by BigChance, on Flickr ![]() 20180522_180757 by BigChance, on Flickr ![]() 20180522_180751 by BigChance, on Flickr ![]() 20180522_180747 by BigChance, on Flickr ![]() 20180522_180720 by BigChance, on Flickr ![]() 20180522_180715 by BigChance, on Flickr ![]() 20180522_180711 by BigChance, on Flickr ![]() 20180522_180702 by BigChance, on Flickr ![]() 20180522_180658 by BigChance, on Flickr ![]() 20180522_180654 by BigChance, on Flickr ![]() 20180522_180651 by BigChance, on Flickr ![]() 20180522_180646 by BigChance, on Flickr ![]() 20180522_180642 by BigChance, on Flickr ![]() 20180522_180632 by BigChance, on Flickr ![]() 20180522_180601 by BigChance, on Flickr ![]() 20180522_180556 by BigChance, on Flickr ![]() 20180522_180535 by BigChance, on Flickr ![]() 20180522_180532 by BigChance, on Flickr ![]() 20180522_180529 by BigChance, on Flickr ![]() 20180522_180525 by BigChance, on Flickr ![]() 20180514_195216 by BigChance, on Flickr ![]() 20180514_195210 by BigChance, on Flickr ![]() 20180514_195206 by BigChance, on Flickr ![]() 20180514_195204 by BigChance, on Flickr ![]() 20180514_195158 by BigChance, on Flickr ![]() 20180514_195154 by BigChance, on Flickr ![]() 20180514_195144 by BigChance, on Flickr ![]() 20180514_195120 by BigChance, on Flickr ![]() 20180514_195126 by BigChance, on Flickr Last edited by BigChance; 06-08-2018 at 10:00 AM.. Reason: Sold |
| ka24de, s13, s14, sr20det, z33 |
