Ka24de High Idle swirl control valve
Ok so i've been searching and can't find anything on this. My idle is stuck at 1500 at start up then once its warmed up and I drive it its at 2000. I sprayed the swirl control valve and it dropped, does any one know why this happened? any one know the fix to this? Thanks in advance!
#2 | |
![]() Join Date: May 2009
You have a vacuum leak, your fix is to replace the line or part that is broken.
