Ls swapped s13 won't shut off with key
having this problem with my ls swapped s13. I've been chasing the problem all over my car. What I've come up with so far is that if I unplug my alternator sensor wire the car will shut off with the key. If I take the accessory relay out under the drivers side kick panel it will start and shut off like normal but with no gauges obviously. And even if I don't start the car and put the key to run (again not start) I have to cycle the key twice from run to off to get the accessory relay to close. There's back feeding somewhere but I can't find it yet. I've tried wiring in a diode on the alt sensor wire because I though current was getting back through it but that didn't do anything. I'm going yo try and trace the power from the accessory relay and see if I can figure out why it stays on. It's a stand alone harness. If anyone has had this problem with a swapped car and a stand alone harness or knows how to fix this I would be eternally grateful. My tune is waiting on this stupid fix.
