First 240! My sr20det s13 coupe build.
New to 240's but not new to tuning and wrenching on cars. Just picked this up already swapped with a sr20det blacktop and some mods.
sr20det isis rs turbo @ 12psi hks ssq bov fmic 3 inch dump tube and exhaust kyb agx adjustable shocks/struts cx racing alum radiator w/ electric fans unknown stage 3 clutch (according to previous owner) Now some pics! It's spray bombed right now (yuck) but that'll change soon. There's a ton of rust underneath which I know is common. Some spots have already been patched (badly) but there's a lot to fix under the car and on the frames. Had horrible stickers on it when I got it (adhesive still there in these pics) Had some sort of alcohol/meth cool mist injection hooked up the the charge piping pre-throttlebody (I yanked it, didn't work) Yanked everything not needed Digital speedo was broke so I swapped an analog cluster in Found a boost leak! Started cleaning the rims and realized they were plasti-dipped black. Replaced the valve cover gasket How it sits now And some fun after I got it (need a welded diff!) |
