Digi Cluster + HUD Troubles
Hi, i buy the HUD + Digi, and have this problem
![]() ![]() Oem Vs digital Here come's the trouble, the OEM are blue one I dont know if exist some way, becouse only 1 plug fit ![]() ![]() |
Is this some kind of troll and did you use google beforehand???
You have to get the harness from the digital cluster. The three plugs connect to ONE BIG PLUG behind and to the right of the harness. So..... 1.) Take your old Analog cluster out. 2.) Unplug analog cluster harness from the big plug behind it where the three plugs come together into a single BIG PLUG. 3.) Plug your Digital cluster harness in to that BIG plug. 4.) Connect your Digital cluster. ![]()
#6 | |
With this are problem fixed right? 89-94 nissan 240sx digital gauge cluster harness s13 sr20det ka24de subharness | eBay |
Be sure to check if the tachometer works on it before you put everything back together. If it doesn't then there are screws directly on the back of the tachometer to remove it and put in your old one. The only reason it wouldnt work is if you bought a single cam digital cluster. If its a dual cam one you should be fine.
Oh and be sure to complain to the guy that sold you the cluster with no harness, thats pretty messed up telling you it was plug and play. ![]()
Ok im going to thread jack real fast haha . I've read that u can use. a single cam heads up display with a Dohc set up aka motor. as long as you exchange the tachometer portion from your old Dohc cluster. Know is this true? or am I reading abunch of old posts on google from stupid people that don't know. Reason I ask is cuz a buddy of mine has a couple single cam digi clusters collecting dust in his garage.
StAySiDeWaYz
#11 | |
