![]() Join Date: Nov 2005
WSRD motorsports ready power steering development.
![]() In our continued attempts to bring you quality products that look good and most importantly WORK, we're developing a motorsports ready v3 power steering kit for the S-chassis. Various adapters will make this work with nearly all of the common engine swaps. Our fourth prototype power steering reservoir features 69in^3 of volume and internal baffling to keep fluid under control. Initial results are very promising, but it needs to see some more serious track time before we deem it ready for production. EDIT: Keep in mind this is a prototype! The production piece will be cleaner and much better looking. We'll also have an optional cooler (Earl's), but I wanted to make sure this can handle some abuse without a cooler, and without blowing fluid everywhere like the factory setup and aftermarket kits. As per our older versions, it features a braided push-lock -10 pump feed, -6 high pressure line with lightweight aluminum power steering fittings, and a nylon braided -6 return line. Last edited by PoorMans180SX; 07-21-2015 at 05:01 AM.. |
![]() Join Date: Dec 2006
now.. I can just have one, right? ......riiiiiiight????
ps..I was looking through my xbox, and found your old username you made on it...mr. JankyS13 ![]()
I have some serious issues with the circuit sports reservoir blowing fluid everywhere after going braided lines. And the fluid gets HOT when on track for extended sessions. We'll be adding a cooler ourselves but I would be interested in another/different reservoir. Would be willing to test it too at the next track night at thompson
Project S14 Begins... |
#6 | ||
A cooler is definitely the ultimate solution. |
![]() Join Date: Oct 2004
I bought one of these and they are awesome.... Maybe next iteration would be one with heat sinks on it like the PBM swirl pots?
Turn and Burn!
#9 | ||
I'll be installing my cooler as soon as the line comes in and posting some updates. |
![]() Join Date: Mar 2009
Off topic but I can't find what thread I saw it in, what brake master cylinder is usable with your brake lines that moves them to the other side of the master? Trying to gain clearance from turbo manifold and downpipe.
Well, after a couple different designs and beating the living daylights out of the steering system, it turns out my reservoir works just fine. However, it's now more efficient for us to turn to the experts at KRC power steering than to fabricate the reservoir ourselves. This is the new reservoir that will come with the kit!
We've designed this kit to withstand constant high rpm without blowing fluid everywhere, and give awesome steering feel. ![]() ![]() ![]() |
