#3631 | |
The Tomei poncams are also 256 with 11.5mm lift. I used them on a 20g set up, which is just a little bigger than a 2871, and they work very well. They idle perfectly even with a/c on and hold power till 8k rpms.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#3632 |
Did you get uprated springs to rev to 8k? Reliably? Or the stock springs ok for that abuse? I know the next week link are the lifters.
#3633 | |
Upgrades springs and duel guide rockers.
#3634 |
I'm running
S13 SR20DET Black top Greddy intake manidold 550cc Sti injectors Megan exhaust manifold 260 12mm lift Tomei pon cams Gt2871r or s15 ball bearing turbo? Power fc d jetro Dynoed at 330whp, 270 tq at 1 bar Injectors were maxed out so I have id1000s on order and going back in for a re tune. Any ideas what I may get with bigger injectors and 20psi? |
#3637 |
#3638 | |
I would use upgraded springs. This was on a 20g not a 2871 but the 20g is just slightly bigger.
#3639 |
![]() Join Date: Sep 2005
You can float the valves at any horse power level, it was probably the rpm that cause the float or an over rev from a missed shift. I make 400hp well within the power band of the stock valve train limits. All without high lift cams and revving to 8krpm that alone reduces the chances of floating valves. At least that's the practice I've been following.
If you're looking at upgrading cams, you should follow the recommendation of the manufacturer, period! Sent from a Highly Tuned Note 4.5!!!
#3640 | |
It was a hp/boost cause. If I tried to go over 22psi they would start to float. If I stayed at 22psi or less it would run clean to 8k Rpms. Above that boost, which was a little over 400hp, they would start to float around 7k Rpms. Tomei says springs aren't needed for the 256 poncams which is probably true on a stock turbo.
#3641 |
Well I can honestly say, with 25psi from a gtx2867r, 415hp and a gt2871r, 448hp my valve train didn't float. So I'll look into it a bit more. I ran greddy easy cams, and jw s3 cams for that test. There's got to be people floating valves left and right, if it's boost related in anyway.
#3642 |
![]() Join Date: Jun 2010
I know a guy who lost his motor because of valve float. He was using JWT S3. I think what it comes down to is fatigue of the stock valve springs. If they still maintain their original seat pressure then all is well, but If they are tired, then you can experience valve float. For this reason, I would choose Procams with upgraded springs over JWT S-Series without.
#3643 | |
All I can say is my experience on the dyno. We backed off the boost and then upped it again twice and the result was the same. Put it on the street and still would get valve float around 22-23psi. Now my 22-23psi is a different airflow than others at that same boost level but the float would start at that point for me and happen around 7k Rpms. We Put springs in the car and have run it to 28psi with out issues.
#3646 |
How I would say tuning.
25psi and greddy easy cams 256/264. That's what it took to break 400hp with the 2867r, but after I put the 2871r back on I forgot to change the boost, and that's what we got! That set in motion, the block sleeving and wiseco piston upgrade. I have now, if the block is capable of 450/500 stock well it only made sense. Next is the transmission! Sent from a Highly Tuned Note 4.5!!!
#3647 | |
#3649 | |
Knowing that your tuner should be able to take advantage of that rpm shift. Sent from a Highly Tuned Note 4.5!!!
#3650 | |
Its defintely valve float. Myself, Martin ( enthalpy ) and my good friend Jerry known as Lancerman in the dsm world all agreed it was valve float. And it went away with upgraded springs. I'm not saying it's simply boost related I'm saying it would happen at 22/23psi and 425hp every time. Turn the boost down to 20 and it would pull to 8k clean and be at 400hp Cams alter your VE and when you retune for that they allow for more power by allowing for more air to make it into the motor vs being trapped in the intake.
#3651 |
K, that's reasonable. Yes, they alter volumetric efficency for a certain rpm range. That's why it's not a huge gain, without tuning. And if you pick the wrong cams you can loose power. I've seen a lot of people slap in some 272 cams and wonder why, they don't make power revving to 8500rpm.
Horsepower curve looking like an excitebike jump. Sent from a Highly Tuned Note 4.5!!!
#3652 | |
Key to going fast is paying attention to the power under the curve not just a peak number.
#3653 |
Car hits the dyno next week, i'm hoping for 380-400 at 18psi.
S13.4 Hybrid Valve Cover S13 sr on stock rebuild. Full 3" exhaust Greddy FMIC GT2871r w/ .64 housing w/ greddy profec II boost controller Greddy Intake Manifold Megan Exhaust Manifold Tomei 260 cams w/ 12mm lift Tomei RAS BC springs & titanium retainers Radium Fuel rail on ID1000's along with an aeromotive FPR. all managed on power fc d jetro. contemplating on if a q45 throttle body is even necessary? anyways i hope i can hit the numbers i want!! ![]() |
#3656 | |
So you have the s15 turbo, aka gt28r, and the gt2560r. Then we mentioned the, gt2860rs which is the disco potato aka gt28rs. Sent from a Highly Tuned Note 4.5!!!
#3657 |
S15 stock camshafts
Gt2871.64 External wastegate Tubular exhaust manifold Greddy intake manifold VR6 throttle body 780 cc injectors 1.2 bar boost - 400whp (gearbox limit) |
#3658 | |
#3659 |
![]() Join Date: Apr 2009
I dont think thats enough boost to make 400whp with stock cams. Atleast Ive never seen it done before. Its very very difficult to hit 400whp with the .64
