NIStune related - need help
Alright, so after going in circles trying to tune my car with a NIStune ecu, I thought I'd consult the internet and see what you all had to say and see if anyone had a saved tune that I could bum. So here are the specs.
1995 S14: - 99 silvia spec R SR20det w/ 6 speed - NIStune type 4 board in ADM ECU w/ modified JDM wire harness - Greddy Profec 2 spec b boost controller - 555cc injectors - Z32 MAF - S15 stock turbo - AEM wideband (runs crazy rich most of the time) - anything else relevent? Anywho. The thing runs rich (as previously stated). It usually hits the 11's and then drops into the 10's and below at 25% throttle or higher. If I'm cruising, it's usually in the 13-14 range and it'll occasionally jump into the red when giving it throttle from a dead stop. I also get a hickup at around 4k and occasionally it'll misfire past 4k at wide open. But I'm getting into too much detail here. Does anyone have a similar setup with a saved nistune doc. that runs well?
'86 Z31 NA, 95 S14 w/ S15 swap |
| nistune, s14, s15, sr20det, turbo |
