![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
Thanks Giving Special!!! Godspeed TD05 18G Turbo Direct Bolt on for SR20 motor
We have a lot people asking for this turbo so we going to throw another thanks giving special!!! please take advantage for this offer cause is only last end of the month!!! Godspeed TD05 18G Turbo. This turbo is Direct Bolt on/Replacement for SR20 Red/Black top, Come with all oil line fitting Spec. Bearing system: Journal Bearing Compressor Wheel Diameter: 50.3 / 68mm TURBINE Wheel Diameter: 49.2 / 56mm Turbine TRIM: 57 Turbine flange type flange: T25 Downpipe flange type : 240sx 5 bolt type Nozzle Area: 8cm² Cooling type : oil and water cooled. Horsepower rating: 300-380 hp BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR) Actuator set at : 14.5 PSI CFM: 600 Direct Bolt on(also work on KA24 if you have T25/T28 manifold) come with all water line and oil line fitting, this turbo is been use on our Redline Time Attack 240SX please watch the video below for more info. YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 1st Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 2nd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 3rd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 4thd Pull $360 Shipped (Lower 48 state) CA buyer will have to pay 9.75% sales Tax Pick up $340 Please PM for Payment Method. Fatboy Garage Motorsport Inc GODSPEED Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 ask for Ken W:godpeedproject.com |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
can't wait to check these vids out! how long have these been out? any reviews? would this be compared to the s15 turbo?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
![]() Join Date: Oct 2006
^^^, would like to know also
#5 | ||
#/f/tech-talk/323337...dyno-test.html Quote:
Thanks |
![]() Join Date: May 2004
The T25 compressor inlet and outlet will not line up correctly with your piping. I had to cut/weld my compressor inlet and I modified my hot pipe to use this turbo with the T25 inlet/outlet. I also had to make a stainless braided return line to use it on my KA-t (xs power manifold, plain your flanges if you use this manifold).
I will say that this turbo is pretty nice. I had mine on for ~1000 miles before I put my car in storage, comes on just a little slower than my T25 did and pulls way harder up top. My only problem that I had was boost creep, mine would creep really bad (up to ~25 psi). I ended up giving up on the internal wastegate and will be going to an external Tial 38mm in the spring when I bring the car home (I store it ~2 hours away from where I live on a farm). An actuator with a longer throw would probably fix the problem. Fatboy did send me an actuator under warranty and was trying to take care of me on it, but I got a good deal on the wastegate so I lost interest in keeping it internally gated. I also had to redo my oil feed line to use a banjo fitting at the turbo, I just used an EVO oil feed line and cut/flared it to have a brake fitting on the other end, then I got an adapter to adapt it to fit a -3 line. This might not be an issue with an SR, but it was for the KA. |
I saw the 20g is going to be released soon, any chance of a td06 20g t3 flanged external wg turbo? Pm me the price if so, and I also sent you a pm about over fenders. Thanks, Brad.
#22 | |
