KAT to SR questions
About two years ago I bot a Greddy kit to turbo my ka motor with 150lbs compression on all four cyl and it ran great until last month when it blew rings in #2. dyno pulled [email protected] Bot a red top SR and have all the Greddy bits. now the questions:
1. can I run the td06-20g on the SR. 2. how big of injectors should I run? Now 370s 3. can I use the e-manage system? will it have to be reprogrammed? 4. How much more power could I expect over stock running at 8-10lbs boost? 5. Whats the best manifold to get? current set up 3 " exhaust FMIC TD06-20g 370s fuel rail walpro fuel pump z32 maf emanage |
