cold started the engine and it rattled (strange rattle like the visco hitting the plastic, wasnt that knock sound) , pressure was there, rattle was gone.
drove. pressure got down pretty bad 1bar (14psi) 3rd gear 50kmh 0.1 - 0.2 (2psi) bar on idle didnt change anything and had perfect oil pressure before. (4-5bar driving) it came out of nowhere any tips or experiences for me? setup: sr20det redtop oil filter relocation kit oil cooler greddy oil pan aluminum (so cant bend onto the strainer like the oem one) new version oil strainer with big hole new version oil squirters with big hole new version chain tensioner new oil pump 2 years before on the cleaned and resealed engine more as enough oil. mobile 1: 5w50 |
Good afternoon, I would replace the small O-rings and check for any leaks.
Upgrade to the s14 oil pickup if you can just to be safe because i had a oil pressure problem also and it helped, man good luck. |
![]() Join Date: Sep 2005
Get a second gauge to verify. your readings now, suggest an oil pump replacement. i'm not gonna assume you have leaks or cavitation problem.
I second a mech gauge right off the factory oil block. If that still doesn't yield positive results, I think you should pull the pump and disassemble it. Sr pumps can crack. 5w-50 is an interesting viscosity... Why that one?
My SR20VET |
@VERT_SR
@cotbu @jr_ss thank you so much for your quick help! i didnt know the oil pump could crack. will check that out after i tested a second gauge. but the cold start rattle really points a pressure problem. @TheRealSy90 nope 5w :> first of all im from bavaria in europe, we get usually around 30°-40° in summer, and 10 - 20° in spring and autum. so its not like miami beach here. (unfortunately) 10° = 50F btw u should change your temp system. water freezes on 0° and boils on 100° isnt that a nice thing? jokes aside 5w means very good oil flow and lubrication when you cold start the engine. and thats a must have for the turbo as well as the motor gets good lubrication as soon as possible. we all drive that oil here with perfect results. 50 on 100degrees is fine as well for most drifting or racing application with an small oil cooler. so best oil choice here imo. cheers! |
I understand the viscosity and C to F. I just don't understand why you would want an oil that flows like a 50 once warm, especially in cooler climates. I use 15w40 in Fl, year round, but we have the weather for it. I would think a 5w40 would suit you needs better. You don't want to increase flow restriction too much, which could strain the pump.
Let us know when you tear into the bottom end/ oil pump.
My SR20VET |
little update.
took my engine out and put it on the motor rack. oil pan removed. strainer is still 100% secure but then i found something. a broken rocker guide. oh shit. turned the engine around and removed the head cover. and tataaaaa. NOTHING MISSING. so the head is still ok. everything where it should be. no guide or shim missing. so i wonder where the broken one in my oil pan comes from. ![]() buuut this could explain the strange rattle i heard. maybe. or maybe not. anways. next step is to remove the oil pump. what could probably be damaged when you find some broken guide? cheers |
UPDATE
after the broken guide i had to check the head. all good tho and nothing missing. ![]() oil strainer is also ok ![]() took the oil pump off ![]() ![]() have to check the bearings next.. ![]() filter looks also good to me ![]() question: can i check the oil canals somehow? air pressure for example? |
well well. the damn guide shot a hole into the oil canal
![]() the oil strainer is also broken now and the wall near the cranshaft got some scratches crankshaft itself looks brandnew tho |
Honestly, looks more and more like installation error. Broken oil squirter, "the wall near the crank shaft" Im gonna say you mean thrust washer area, for sake of argument.
Sent from my LG-H631 using Tapatalk
| oil problem, pressure, sr20det |
