![]() Join Date: Jan 2009
S13 SR20DET REDTOP
-Wiseco 86.5mm pistons -Eagle rods -ARP main,head,con rod hardware -Ported head -HKS 264 step 2 cams -Tomei solid lifters -Brian Crower valve springs with ti retainers -Rocker arm stoppers -Greddy Adjustable cam gears -Line bored crank main, and cam -Balanced rotating assembly -New timing chain guides and new style tensioner -Cometic head gasket -Ogura single plate clutch/flywheel combo -Stock sr 5-speed -Stainlees turbo lines -Stock sr T-25 -Stock s13 sr ecu -Stock sr 370cc injectors -Starter -Full sr harnees ready for s13 needs mafs and o2 sensor extended. -Licence plate heat sheild -Freddy oil pan -Freddy intake manifold Powder coated wrinkle finish to match valve cover. -Spare valve shims Anymore info i left out i will update, along with pictures. I'm open to trades for baller stuff like 18x10.5-18x13 wheels low offset weds work etc,2jzgte,ls1,dope 1jzgte,caged rolling shells s13 s14 sc300 with goodies. In otherwords equal value or partial trades with cash on top. Price:$4500 Only PM's or contact in the thread i dont currently have a phone. if you pm me your number i will call or text you as soon as i can. Thanks for looking everyone! BUMPS are welcomed! Some pics will be updating tonight: |
| 1jzgte, 2jzgte, ls1, rb26dett, sr20det |
