Engine Tech Technical discussion related to all relevant engines such as KA, SR, RB, CA, 2JZ , L24/26/28, VG, VQ, and LSx series. |
06-07-2021, 10:51 AM | #3 |
That is a distributor for a KA24DE.
06-07-2021, 11:14 AM | #5 |
Haha for sure. I think that's an S13 one, S14 might be a little different due to the integrated coil, I've never taken one of those apart before.
06-07-2021, 11:42 AM | #6 | |
Looks like a 360/4 slit (slits of differing width depending on Cyl 1-4) CAS wheel |
06-08-2021, 01:10 PM | #7 | |
strangest thing though... i got it from a guy who swears its out of an s15 sr20det. he gave it to me free... no reason to lie.... And another weird thing... how would the computer know when to fire the injectors if the slits are all the same length? It would need some other kind of crank sensor. I should take a closer look at the disc... was there ever an SR or KA engine that uses batch fire injection or has some alternative crank sensor? |
06-08-2021, 01:38 PM | #8 |
It's definitely a distributor. But yeah, the guy is probably 1/2 right; it's from a S15, just not a DET. A standard DE, sure.
Rotate the wheel some more. This also may be a 360/1 (where 1 slit is larger than all three) which signifies TDC. ECU really only needs one reference point for TDC, and it just counts the slits for the remaining 3 cylinders. https://www.diyautotune.com/support/...rt-your-240sx/ Don't think any SR or KA used batch fire (unless the KA24E maybe??) |
06-08-2021, 07:00 PM | #9 |
Well now I'm dying to try it inside a det just to see if the ecu can make sense of it. The guy never owned a sr20de engine; I tuned his s15 silvia a couple times over the years and thats the only engine he ever owned so... I just wonder. If, you know, the ecu could make sense of it, even though its wrong for the engine. Hmmmmm
So weird. |
06-08-2021, 08:27 PM | #10 |
Not sure. The DET ecu has the coil drivers. The DE ecu does not
Also, if the CAS wheel is different and the optical pickup is different it won't work P.s DE and DET engines are almost identical external sans the ports for the oil and coolant feed being tapped on the DET as opposed to the DE where they are not. Valve cover is raw/khaki color as opposed to painted on the DET. He may had had a converted DE to DET and not have know...or got it from a random parts stash. Who knows lol Everything else bolts up. CAS in place of the dizzy. Etc |
06-09-2021, 07:09 PM | #11 | |
So I am wondering if the DET ecu can do the same thing with a CAS like this one. Maybe it can use the one large window to determine piston position forthright and from that point on it can run the engine just fine... Too bad sr engines are extinct antique priceless legendary artifacts |
