Substitute paint for KG5 (Ivory White)
I've been searching around for a color similar to the oem ivory white, ive looked in autozone and orilleys for the duplicolor exact match spray cans but I've had no luck, I've read somewhere else that they have used a Heron White? But no luck finding it also, the guys at autozone or oreilleys are no help either, i don't know how similar the Cloud White from Nissan is to the Ivory white, anyone has any ideas to where i can find something similar?? thanks
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2 |
Have you talked with someone in the parts department at a Nissan dealership?
Do need the Factory Service Manual? Click here. |
http://www.paintscratch.com/
^Will do a custom mix for you and put it in a can for you... or... You can go to a local automotive paint shop and get a mix of it for like $35 and then go to Lowes/Home Depot/O'reilly's and buy the Preval sprayer kit for $5 to put your locally mixed paint in. |
Or you can buy touch up pens from Courtesyparts.com
My SR20VET |
Touch up pens won't work due to it being a fairly medium part lol, and yeah I've called around found the replacement thanks
