1990 240sx Transmission issue
So I just recently bought a 90 240sx with AUTOMATIC TRANSMISSION SOHC ka24e.
150K miles all stock. So what I've noticed is when I take off and second gear kicks in usual its a very smooth shift but with mine there's a hard kick/pulling feeling. All the other gears go in smooth. So my question is what can it be? could it be my tranny, torque converter going bad? I also noticed I need to replace motor mounts. I would assume if it was pulling when shifting cause if motor mounts it would kick/pull in all gears. Any thoughts please let me know. Thanks |
![]() Join Date: Jul 2013
sounds like the trans is damaged (clutch packs, etc) try putting some lucas auto trans treatment in it, it might help.
Have you considered a 5 speed transmission conversion?
95 S14 se RB25DET 348whp
