'95 S14 KADE Parts, Sensors, SR Silicone Hoses, Misc. Ish
I basically what amounts to 2 full motors. If it came on a motor than I probably have it so ask. Trying to get my injectors cleaned and flow tested to get this snail breathing so everything is OBO. Prices are shipped priority in Cont.US. My email is [email protected] (use for paypal 2)
KADE Knock Sensors W/Pigtail (2) SOLD exhaust mani w/egr tube SOLD KADE Complete Head Minus Cams (2) (Probably got them if you want) $150 KA Block #1 (has spun bearing, good for parts or rebuild) MAKE OFFER KA Block #2 (running condition, has torque converter) MAKE OFFER KA Oil Pan (Used but mint, no dents, minor scratches) $75 KA AC Compressor W/bracket and bolts (No Lines) $45 KADE Complete Intake (W/TB,TPS,Eeerthang) SOLD KADE Upper Intake (Missing minor hoses) SOLD KADE Lower Intake (No TB, EGR Delete) SOLD/ Lower Harness And Sensors Still Available KADE Valve Cover $45 KADE Upper Chain Cover $35 KADE Front Cover (Working Order) SOLD S14 Front Struts $35(Don't think I want to ship these unless you pay) S14 RUCAS and Tension Rods $20/set S14 Toe Rods $20 Battery Hold Down (No J Bolts) Free With Purchase KADE Alternator Bracket $10 KADE Cam Gears W/Bolts $10 KADE Trans Bracket $15/Set KADE Motor Mount Brackets $15/Set KADE Transmission Crossmember and Mount $40 S14 5 Speed ABS Driveshaft $150 PICKED UP/NO SHIPPING Water Pump Pulleys $10 Power Steering Pulleys $10 Distributor (External Coil, Works but broken cap) $45 What I believe to be SR Radiator Hoses, bought them without seeing a picture and obviously not for a KA $35 LMK if you need any small stuff, or extra pictures, questions, what eva Thanks for Looking SiDwAyZ Last edited by SiDwAyZ240; 04-16-2012 at 06:48 PM.. Reason: Sold Parts / Lowered Prices |
I still got the valve cover, knock sensor, and the oil pan. Lower intake is gone but all the sensors and harness are still available. I still got that s14 ABS driveshaft too, Wreckless is MIA. LMK and we can work something out.
#12 | |
![]() Join Date: Jul 2003
Trader Rating: (357)
Have a picture of the sensors/harness from the lower manifold? |
Not sure what part your talking about. Manifold went to the scrap yard and everything was taken off before hand except for EGR stuff which was already deleted. If it's not in the pictures I might have it set aside somewhere. LMK exactly what your looking for and I'll see if I can find it. |
#16 | |
#17 |
Sorry but piece is MIA. Not sure but it may have been deleted off of the manifold parts I have left. The 1 in the picture got sold, but I had another complete head that I scrapped and took all the stuff off of, the only thing I remember it missing was the egr stuff.
#20 | |
