![]() Join Date: Apr 2013
SR20det no start!
I'm stumped, I could use all the info I can get. Car has spark and injectors fire when I turn the CAS by hand but when it's installed the spark is not noticeable and the injectors will not fire. Yes I am timing it right and have tested other CAS and ECU's. It's like the block is grounding out the signal once the CAS is installed.
#3 | |
I appreciate the reply, I have pinned out the CAS to the ecu, all of them have continuity, and the power to it is receiving 1.7v. Sent from my iPhone using Tapatalk |
