S14 Stock Interior and Exterior
: Ro
: Loudoun County, VA : Post/PM for faster response : NO Trades : Paypal+3% or CASH : Free Shipping on certain items or local pickup All parts are taken from a '95 Zenki Emerald Door Panels(Passenger and Driver) 8/10 condition $25 each Brake Master Cylinder w/Booster Works fine, No problems, No leaks $100 Seats w/Rails 9/10 condition.some cig burn marks $125both Guage Cluster All working lights $80 Shift Boot - torn up a bit SOLD Nismo Shift knob(threads on fine) $80 Sunroof control/Map light $5 DRIVER side Fender No damage, No rust $30 -- Pending I have the passenger fender also but has rust on the lower mounting area; take it if you want it Gas Tank No leaks $100 Radio Trim w/slight crack, broken tab(still mounts fine)and missing cig. plug (Does NOT come with guage setup) $60 Radio trim and guage setup - $100 A/C Trim No damage, except the drill holes between vents (Does NOT come with guage setup) $45 A/C trim, 2 guages, and boost control setup - $250 Auto Meter Sport Comp #3303 Boost/Vacuum, 30 in. Hg./30 psi Mechanical, 52mm - Needs plastic tubing $40 Auto Meter Sport Comp #3344 Pyrometer, 0-1,600 Degrees F Electrical, 52mm - Comes with everything needed; Type K thermocouple and wiring harness $120 Auto Meter Sport Comp #3327 Oil Pressure, 0-100 psi. Electrical, 52mm - Needs 1/8in. NPT sender and 1/4 in. NPT adapter/fitting. $45 TurboSmart Boost Controller In-Cabin adjust w/ T-fitting $95 Whole Setup(A/C trim setup + Radio trim setup) - $335 Last edited by roorr0; 08-19-2009 at 11:13 PM.. |
![]() Join Date: Apr 2005
I think I might take the seats.. however I'm at work so I cant see the pictures. I'll let you know when I get home.
***PM for Stereo Help*** Eclipse55090CrystalSSCS6SIMAG |
#9 | ||||
Check out the New Parts Added Quote:
Fenders are PENDING and NEW PARTS ADDED! |
I'm in chesapeake..kind of a while from you.. but I might just paypal you and have you drop em off at a friends house up/picked up there in NOVA...
oh btw.. are these teh blue variety or gray? I cant tell.. and do you have seatbelts as well? thx!
#11 | |
i can try to find the seat belts. and it is the greenish color interior..expect for the trim |
Pleae email me (faster) or PM me if the driver's side fender sale doesn't go through. SERIOUSLY need one of these.
sunistrimza AT gmail.com
(sold) '96 S14b Zenki4ever |
