KA24DE won't start after changing injector and dying
My car was running without any issues up until recently. It's a 1991 240sx SE, the issue is that I went to start it up one morning and the whole car was shaking and that was because the engine was going crazy side to side and wasn't running smooth. I checked plugs and wires and there's spark, but then I pulled the injector wires one by one till I found one that didn't affect the engine meaning there was something wrong with it. I replaced the injector and got it start but it was flooded so I had to pull the fuel pump relay to get it started. I got it running with the replacement injector and although the start up was rough it smoothed out to how it was before on all 4 cylinders. I then took it down the street and it died, and I can't get it to start again. All the plugs were fouled and wet so I think it's either too much gas or not enough spark. I tested for leaky injectors and the replacement leaked a minuscule amount once and wouldn't do it again. The o rings seemed fine and there were no visible damage.
Whatever happened to the engine happened overnight if that helps to figure out probable causes. Thanks, |
![]() Join Date: Apr 2011
Did u change the o rings on the injectors ?
also the seals around the intake Mani were the injectors plug in hope this helps good luck *Sometimes the o rings look good, but i believe they warp size . kind of like the ring for the fuel pump
my brother just replaced number 1 injector. and now the car wont start. it has spark and ran fine before replacing it. we are getting fuel on spark plug 1 and 3 but not 2 and 4. checked timing days before injector went bad and was fine. do you guys think maybe its a bad o ring letting to much air in the mix.
