![]() Join Date: Sep 2006
KA24E Hose connexions -air regulator etc.
I removed 2 hoses. One was a small "U" hose and the other was to the AICV. There are 3 ports labeled "1" "2" "3".Which 2 are connected by short "U" hose?
And which port goes to the IACV? ![]() |
im pretty sure 3 goes to iacv and 1 uses the U shape and connects to the air regulator
Hoses
OK 1 & 2 loop and 3 to AICV Thanks. BTW The dealer calls the IACV "AICV".
If you ever call the dealer--it gets confusing. I own the service manual which has that diagram......it doesn't show what I pointed out in my photo Last edited by miklos; 05-11-2009 at 06:35 PM.. Reason: new info |
![]() Join Date: Mar 2002
Unless I don't understand what you are asking that photo shows exactly what you need.
The AAC valve goes has the hose that goes to #3 in your picture and it is #14 in the service manual picture. Your #1 and #2 are #13 in the FSM picture.
90 240sx Coupe |
in your original post you asked which pipe the u shaped line connects to, i answered it already its #1
