#61 |
![]() Join Date: Jul 2007
Trader Rating: (106)
Actually if you spray the inside of the offending hose/nipple with carb cleaner the hose will slide right on. The carb cleaner evaporates away and doesn't leave any residue between the hose and the nipple. You just have to be fast because it evaporates...
#63 | ||
I always fill up transmission oil from the shifter. It's pretty easy and beats crawling under the car. |
#64 |
Awesome thread.
![]() i have a few of my own from many days and nights spent cursing and scuffing my knuckles - Got a stubborn bolt and dont have impact tools? Tap the wrench/rachet you are using to loosen the bolt with a hammer. Ive gotten really tough bolts out that way. Works the same way as an impact gun. - Freeze off is better than holy water. that has replaced the PB blaster in my toolbox. - When doing caliper work, zip ties are your friend. - ***TIME SAVER*** If you are doing a multi-step job, and one step is a PITA (ie. knock sensor) just do that PITA step FIRST, and do the easy ones later. It sucks running out of daylight, when you still have the pita part of the job to do. |
#65 | ||
I've broken the neck of old radiators doing it this way Quote:
I like to use short tie downs with hooks on them to hold brake calipers and suspension components out of the way and keep stress off brake lines bringing down a transmission: loosen motor mounts to swivel motor towards you then you can get a long extension on the hard to reach bolts you can also get at the top ones from above with a ratcheting wrench but can end up with bruised knuckles motor mounts: put a jack under the transmission mount to support the motor loosen and lower the crossmember about 1/2" that will give you room to get the mounts out use a swivel socket to get at the 14mm motor mount bolts |
#66 |
sweet thread.
a recent trick i found to remove flywheel bolts without an impact. install a bolt into one of the transmission holes on the block. lay a pickle fork or large screw driver over the bolt and lodge it into the teeth of the flywheel. use your breaker on the flywheel bolt obviously and pop it loose. another version that works i used on a 1j the other day was to bolt a 14mm wrench down to the transmission bolt hole and put a pressure plate bolt into the flywheel and pop the flywheel bolts loose that way. im used to working alone so i rarely have that buddy to help fight against a bolt |
#67 |
![]() Join Date: May 2006
i made my own little table for head work especially when installing or taking out valve springs plus porting and polishing work.
its made of wood ![]() ![]() ![]()
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
#68 | |
![]() Join Date: Sep 2006
anyways a tip. download and print the FSMS! follow torque specs! |
#69 | |
![]() Join Date: Sep 2009
Oooh please post some pics and specs. I've been wondering how to make one for the longest time. My contribution: If you are trying to take out old and worn bushings, burn them out instead of a press. It is a lot faster I think plus not everyone has an access to a press. Just clean them out after their cool, repaint, and install new bushings. |
#70 |
when trying to figure out the length of hard lines, or any type of line in your car, like vacuum ones that are still on
grab a shoe lace and use that, or use some thick string (so it doesnt break if you need to pull it hard) and then trace it and measure the lenght. i needed that for hard lines yesterday |
#71 |
![]() Join Date: Dec 2008
gearwrench or any other ratcheting wrench, these things are the greatest!!!
also, buy gearwrench brand over craftsman, they have the same lifetime warranty at sears and they're like 1/2 the price and better quality...i worked at sears for 5 years, they're amazing, AND at least once a month they go on sale for like 50% off!!! get on it!
thelittlebigblock.blogspot.com |
#73 | |
Yep or put them in zip lock bags and label them.
Almost there. |
#74 |
![]() Join Date: Nov 2006
For transmission bolts, instead of trying to get your wrench/hands up there in those tight spaces to get to the bolts, just put together a bunch of extensions and a universal joint and just feed it up from the drive shaft area. You can usually get to all the bolts easily this way and just chill out on your back (if you're working on the floor) while you do it.
Also, the hood mod/remove your hood when doing anything on the engine. So much more space. |
#75 |
Buy or make this tool for removing exhaust hangers. Charge your frustrated friends money or beer to borrow this tool when they try to install their ebay exhaust.
My shoe is undesired |
#76 | |
![]() dont waste your time stripping hardline fittings. just use these. |
#77 |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
When your reinstalling the transmission don't bother putting the top 2 bolts of the bell housing back on. If its good enough for Nascar its good enough for your little S13.
#78 |
For S13 chassis:
Use black duct tape to redo or add pinstripes on your car, make sure you leave extra tape on the ends because they shrink in the heat. Also make sure the lines are straight or else they will look ghetto.
dying is only living, dying to live
#80 |
![]() Join Date: Dec 2003
OH OH OH.... I've got a good one, remembered this last night when I was doing some wiring.
When ever you have to wire something, especially if it has a decent amperage draw (fan wiring, etc..) and have to connect two or more wires. Stagger the wire cuts like an AT&T "raising the bar" commercial. This not only ensures that you'll avoid connectivity if your heat shrink fails but also keeps from having that "tumor" when you wrap your new connection with tape or more heat shrink. Motorcycle/bicycle related trick... used compressed air to remove hand grips; just blow between the bar and grip and it'll slip right off every time. I'm sure its fine but come on, that's just lazy... Put ALL your bolts back on...
#82 |
Sure does, but usually not needed.
#83 |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
My motorcycle bars have grooves in them to hold the grip- also prevents it from sliding on easily. Some people use spray glue, so when its wet theyll slide on and then it dries and holds them on. I find that it just makes a mess. So I slide em on with the help of a bit of air, and use no adhesive.
![]() If youre ever stuck using a scissor jack... pop a socket over the little loop that youre supposed to turn, and hit that bitch with an impact. Beats the shit out of cranking it up for 45 mins. Ive done many motor swaps with the only jack available being a scissor jack... this was a lifesaver. |
#84 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
buy a label maker for after market wiring marking...and put labels every foot or 1'1/2''... itll save you having to go back and fourth or having someoen to tug on the wires and yell out which is which...lol
PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r
#85 |
If you are doing a full brake system flush, flip the brake fluid bottle upside-down in the reservoir so you don't have to keep checking the fluid level while you bleed.
Chris @ DeatschWerks.com Fueling Your Passion for Performance! |
#86 |
Best trick ive ever learned in my life was gravity bleeding. I have a vacuum pump, speed bleeders, but I tossed all of that for the OE fittings. I could completely drain the fluid, and fully bleed them all by simply loosening the bleeders slightly and letting them bleed.
I keep an eye on the fluid level, and refill after I use up a whole bottle of Valvoline blue. Works perfectly on all my cars, plus you dont even need to jack the car up for it. |
#87 |
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
if you dont have a spark plug socket, or lost the rubber thing inside::
use a small 1/4inch tube. slip it over the tip, use it to start threading the plugs. if you cant break your crank pulley nut loose::: put the socket and a breaker bar on it, let it rest on the ground. quickly turn key to start then off immediately. itll break that shit loose |
#88 | |
Harbor Freight is my tool source. I only buy their tools that have a lifetime warranty. They break, you bring them back in and get new ones on the spot. Those tools are cheap yet are pretty good quality. Zip ties will fix almost anything non-mechanical (body kits, headlights, etc.) The ball on the driver and passenger sides before the rear wheel well is a perfect jacking point. Don't get frustrated when an interior trim piece isn't budging. Chances are you missed a bolt or just are not pulling from the right area. Walk away and come back otherwise you might just crack/break the piece.
#89 |
Use the spark plug wire to remove the spark plugs if you don't have the rubber socket insert.
To run my A-pillar gauge wires I folded a piece of electrical tape back on itself, slid it through the slit of the dash and the A-pillar. Then I used that piece of tape to bring the wire up. or Enter the wire from the top, then tie it to itself creating a loop. Feed the loop up through the dash and a-pillar slit then untape and enjoy. Also, tape your connectors so they don't snag and make you cry as you route them. |
