![]() Join Date: Aug 2006
hood latch
sooo
my tires ate my hood latch. then i tried popping my hood one day by pulling the wire to the front of the car and using a wrench to pop it. and the whole latch just came off the front. j/w if this has happened to anyone... and how do you pop your hood now? need help asap... i wana do an oilchange soon-ish and so i can put my fuel press and oil temp gauges in. |
You're kind of screwed. If you have tiny hands remove your cover under the bottom of the car, reach up behind the bumper n front of the ac condenser/radiator, and try to get a 12mm on the screws for the hood latch...should be three of them. I've never tried to get them off with the hood shut before though. It's all I can think of.
-Retired Last edited by 98s14inaz; 08-18-2008 at 12:07 PM.. |
![]() Join Date: Dec 2002
Hood latch bolts are M8, 12mm head.
i moved mine inside my engine bay, before the problem occured, while moving my wiring harness further north.
zipties ftmfw! ![]() ![]()
1995 S14 NonSunroof. |
maybe something like this?
AeroCatch Lightweight Hood Pins - Locking i wouldnt recommend running basic hood pins. seeing as how anyone would have access to opening up your hood. btw.... your cars not low enough........ <3 Tyler |
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() Feedback Score: 16 reviews
dam man, yeah just try to get in there somehow
jw, can u post pics of your car? from your sig, your shit looks LOW and has dope ass fitment hha
Banana boat chronicles |
#8 | ||||
the hood latch was torn off. thanks anyway tho. Quote:
![]() hahaha, well, i have no money, so this is gona have to be ghetto as hell... i need to open it somehow and put it back in or somethiiiiiing thanks i'll see if i can fit my hands in there Quote:
hahaha no worries... if i ever got to the bolt i woulda realized it was too small anyway... |
#10 | |
no i don't. so i should be able to just take the bolts off thru there then? |
#11 | |
![]() Join Date: Dec 2006
new latch is around 50 bucks from the dealer.
#12 | |
alright cool, will try that out 2morrow then. thanks |
oh wow, i thought i was the only that happened to, except that mine hast ripped through yet. its just worn almost all the way through. and it wouldnt let me ever latch the hood. it kinda sucks...
and i honestly dont want to buy hood pins ![]() |
#14 | |
mines not only ripped thru. after that, it fell out. |
#17 |
i had that recently happen to me.. for the s13 there is three 12 mm bolts that you can take off just reach under to where you open the hood from and u should feel the bolts there. It only took me 2 minutes after a kind zilvian showed me where it was at
#18 | |
btw did you get that hood open? |
#19 | |
alright cool. cuz that ipod shit was wayyyyyyy off... 2871r setup 2 7psi. said i had a 2.8 60ft and a 13.5 1/4 with 494 hp. haha just trying to get it closer to what i could possibly be. |
#20 |
alright... so for a future reference for anyone...
there's 3 bolts when u look right in from where the grill is... i didn't have my grill on so it was really easy to get. unscrew them, lift the hood, insert latch cable back in. pull it with a wrench and make sure you catch it!! hahah |
#22 | |
![]() lets cruise fucker. |
