240sx parts s14 s13 z32 sr20det
Good evening,
Clearing out storage and making room for new stuff. All items are available unless noted. Will post more items later. Also don't hesitate to ask for pics via mobile phone. UPDATED** S14: Sun visors $40 S14 front tension rods, no bolts($20) S14 jdm intake air box $20 S14 jdm and usdm egr canisters $20 each S14 4lug drilled slotted rotors (complete set, $40) S14 fuse panel cover $10 S14 suspension kyb oem shock/strut combo $160 (complete set) S14 Diftech bushings, diff only. (brand new open box, $30) S14 rear lower control arms $40 S13 diff cover(missing studs) $20 Z32 non turbo wheel hub 1x $60 S13 front tension rods, can use new bushings ($20) Sr20det: S13 T25 turbo,lines ($200) Like new spec clutch stage 2(flywheel, clutch disc, pressure plate) only used to turn on engine. $300 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my LM-G710 using Tapatalk |
