TOMEI Expreme Exhaust Manifold and Turbo Outlet *** New Lowered Price ***
***** Optional Service High Temp Heat Coating - $199 For Both *****
Expreme SR20DET Exhaust Manifold - $531 + Shipping
Our EXPREME exhaust manifold is now available for SR20 owners who want a performance upgraded from the genuine exhaust manifold. With our product you can retain the genuine setup and no special modifications are needed to fit the standard turbo. With the SR20DET the exhaust manifold was designed to be close from the exhaust port to the turbine. With the comparison test of our isometric prototype & the factory genuine manifold which also utilizes the same layout, it shows that ours has succeeded in delivering an overall improved performance in both torque and power increase in areas like in the higher RPM range in which you were not able to utilize before. With our extensive testing we have reached the conclusion that the normal design is superior as a total overall efficiency. So to develop an exhaust manifold similar with the design and setup as the factory manifold we were finally able to produce a product worthy to bear our name as a product that has the potential to deliver an overall increase in performance.
Expreme SR20DET Turbo Outlet - $171 + Shipping
The genuine turbine outlet diameter is small which causes the secondary exhaust pressure to rise. This in turn results in a loss of power, response & unstable pressure. The TOMEI outlet has a larger internal diameter for the best optimization of exhaust flow efficiency & helps reduce the exhaust pressure substantially. If used in conjunction with our TOMEI ARMS turbine. You will see large gains in all aspects of performance. The corrosion-resistant stainless steel material used in manufacturing this product is good with heat resistance up to the flange.
