violent movement in the rear
Hey, I have an s13 and recently got wheels enkei rpf1 with n1 racing slicks already on them. I lowered the car about another 1.25inch right before i installed the enkeis. I started to drive and the wheels started shaking really hard. I stop the car, jacked it up and double checked the lugs and made sure it was all flushed and torqued. I started to go forward and it continued, then I backed up to see if it did that way but there was no shaking. I started wondering if lowering the car affected my toe and are the slicks making it worse bc of its traction. so I asked a friend and he told me I needed adjustable toe arms. I just wanted to know does this sound right? its shakes so bad its undrivable but only going forward. I can visually see the toe is really pointed inwards but would it cause that crazy shaking? keep in mind it didn't do this with my other wheels just before i took them off and the wheels i installed has no bends and are balanced. all the bushings are fine as well. thanks guys
EVO X GSR and R32 GTR |
i seemed to have the same violent shaking in my '90 hatche'
i dont know if you have the same set-up but from my standpoint the connecting arms on the rear wheels of my car were the issue. it turned out that the adjustment bolts on my traction rods/arms had come loose (on just one side mind you) and this caused my traction rod to self adjust as the car was moving!!? thus causing the entire car to literally begin shaking like it was just looking for a tree to hit or something stupid... you said you have AM wheels but not anything about upper/lower/traction/toe rods in the REAR check your bolts to see if they are all tight and perhaps seek another alignment. after i tightened just the two retaining bolts on the traction rod (just the one side) the car sings down the road without any death wobble. hope this helps -EmericanA |
about 5mph i just put into 1st and let it move on its own, yup professionally balanced.
![]() Join Date: Oct 2006
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
The toe is off badly enough that the slicks are wheel hopping. That's why it only does it with slicks and not in reverse.
I had a cool signature |
you sir are awesome thanks so much this crap was killing me, also wheel hopping can happen at 5mph? and what exactly is wheel hopping. i just ordered spl v3 toe arms. will i need anything else?
