Banned from the Marketplace
![]() Join Date: Oct 2008
Trader Rating: (32)
![]() Feedback Score: 32 reviews
***Complete part out of Nissan 240sx S13 and s14 s15 Silvia front ends***
Send me a PM OR leave a message Here. I have many more parts that aren't listed.. S13 = 1989-1994 S14 = 1995-1998 S15 = 1999-2002 Exterior: (**Front ends, Bumper, Fenders, Hood, Doors, Rear quarter panel, Rear bumpers**) s13-s14-s15 S13 Front clip Aka Radaitor Support with Apron $120 obo 89-94 NO FRAME DAMAGED out of a 1991 se S14 front clip aka radaitor support with apron $200 95-98 NO FRAME DAMAGED out of a 1996 se - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Headlights pop up S13 headlights $40 95-96 S14 zenki headlights no broken tabs $200 89-02 S15 Silvia Headlights $600 No broken tabs - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Fenders (fender linner, metal fender, fiberglass, bracket, screws,) 89-94 Driver side Metal fenders $50 passenger $20 has dent 95-96 driverside fender $80 oem green passenger fender $20 has dents 95-98 s14.5 Fender fiber glass driverside only $20 95-98 s14.5 Converison Fender fiber glass Vent 20mm only $150 obo S13 GOOD CLEAN fender linner - $20 each s14 fender liners all around with bottom guard $50 no damaged Exterior - Rear metal quarter panel 89-94 rear hatchback $80 pick up only driverside Rear metal quarter panel 95-98 rear $200 pick up only driverside and passenger Rear quarter panel WIDE BODY B-Magic Aero 30mm 95-98 FRP FENDER $250 obo CLEAN - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Hoods (Fiberglass, oem metal, carbon fiber) 89-94 s13 pop up headlight hood 240sx $40 95-96 green zenki hood $150 obo - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Rear trunk (glass, hatchback, Trunk lid) sunroof glass no RUST OEM NISSAN 95-98 $200 89-94 clean wingless coupe trunk $100 obo 95-98 wingless trunk s14 $100 obo 95-98 oem peral white 1996 se trunk with spoiler $150 95-98 oem Green/blue se trunk with spoiler $150 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Bumpers (bumper cover, metal bumper support reinforcement, foam) s15 89-02 Front bumper $40 fiberglass has minor cracks Spec r replica 91-94 240sx Pop up headlight, Chuki Front bumper with SE LIP $150 89-94 Rear Coupe/convertible bumper Clean $80 89-94 front $20 or rear bumper support $20 each S13 240sx bumper support foam $20 Jdm zenki bumper $200 No broken tabs.. Direct bolt on to 95-96 usdm car USDM ZEnki bumper $100 ZENKI BUMPER/HEADLIGHT RETAINER CLEAN $75 Tail Lights d-max style LED 180sx tail light $200 obo left and right (hatchback) 89-94 tail light $100 a set! OEM obo coupe, convertible, hatchback 95-98 S14a Kouki Complete TAIL-LIGHT $350 obo - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Doors (motor, window, switches) 89-94 clean pasenger door with manual tinted windows - $100 complete clean clean white paint 89-94 Power windows Doors Complete - $300 a set complete door and harness, motor/ regulater/ tinted glass included Mirror 89-94 driver/passenger side mirror - $40 each power or manual 95-98 driver/passenger side mirror - $40 each Interior (*Seats, interior panels, arm rest, center piece, dashboard, etc**) 89-90 single cluster $60 95-98 white face cluster SE ~114k $200, ~162k $130 97-98 kouki base model cluster $80 ~175k Clean black cluster trim $30 95-98 Arm rest $40 8 out of 10 Nissan 240sx 1989 - 1994 Hatchback, Convertible, Coupe A/C CLIMATE CONTROL - 89-94 $30 95-98 $50 89-94 OEM coupe quarter window glass - $80 each obo hatchback rear black quarter panels - $30 each or $50 for both 89-98 Glove box $20 Nissan 240sx 1995 - 1998 Zenki, Kouki S14a Door Panels -$50 a set rear black quarter panel - $40 for both (interior) Airbag Driverside and passenger r - $200 or 150 each passenger side no cracks 1/4 quarter panel glass- $30 automatic gear shifter - $20 Internals: ( **Engine, Transmission, Brakes, Suspension, Control arms, Axle**) s13 abs brake module/system $40 no problem whatsoever.. Complete 5 Lug Conversion $500 fits all year 1989-1998 Brake System - - - 89-98 S13 Stock Front brake caliper with brake pad $25 each or $40 for both - - - 89-94 Rear caliper $40 each. GOOD SEAL NO LEAKS!l - - - Front 180sx big piston caliper $100 pair WITH 4 lug ROTOR - Engine and Transmission 1996 SE 114k Clean engine Low mileages complete swap with auto tranny $700 1995 SE 162k blown headgasket complete swap $550 complete swap with auto transmission 1990 Sohc complete engine swap with bad head $200 with auto transmission 1990 sohc ~129k running health engine no leaks $450 motor only. NEW Delrin Stiff Motor Mounts KA/SR Direct bolt on - $100 A SET 91-94 Automatic Transmission with only ~73,xxx $200 89-90 KA24E Clutch + Flywheel kit $80 89-90; 91-94 single cam 240sx stock header - $30 89-98 starter $50 ( working condition can go with you to autozone to test it out.) 91-98 twin cam header shield - $20 off a s14 1995 91-94 S13 dohc down pipe weld to your exhaust- $20 MAF (mass air flow sensor) SOHC 89-90 $60 , S14 97-98 $200 [SIZE="4"- Engine and Transmission[/size]-Front + Rear Suspension [SIZE="4"- Engine and Transmission[/size][/size] 89-94 Apexi Coilovers N1 Nearly NEW $1200 obo ~300 miles 89-94 Teins Drift Spec Coilovers $800 ~11,000 miles S13 subframe clean $100 ; S14 $150 95-98 $130 each ,89 -94 open diff aka 3rd member, pumkin COMPLETE $80 each 89-98 s13, s14 6 bolt axle $35 each s13 or s14 Stock shocks and spring $150 obo Complete front and rear. 89-94 s13 rear control arm $50 each s14 $100 Each s13 or s14 traction arm, toe arm, camber arms - $20 each. s13 hub+spindle - $40 each side.or $150 for complete s13 front lower control arm -$35 each s13 front/rear sway bar - $20 each Exhaust System OEM CAT $140 Aftermarket cat converters $20 89-94 Coupe, fastback, hatchback, convertible Rs-R GT-2 Full catback $350. DIRECT BOLT ON OEM SETTING Donuts/ Spare $20 each. Stock steelies - $20 each (tires will need replace) rolling shell with paperwork $800. Tag expired may 2010. |
all for for 89-94 s13 hatch
s13 subframe pics? how much shipped? front bumper chuki with lip how much shipped? how much just for lip? front fenders? condition? pics of all please lmk if you can ship and how much to 84120 |
#23 |
Trader Rating: (32)
sorry no shipping on big heavy items!!
The white shell is up for $1000 after 5 lug is taken out. Pmed for more info? if you guys are serious. |
