Hello friends!
My name is Fernando from Argentina, I have a Nissan Silvia S14 Zenki SR20DET LHD. I have a big problem! The engine not start and I dont have spark. I made this: 1. Check the ignition relay = WAS OK (next to the ECU motor, passenger side) 2. Check the ignition fuse 7.5A = WAS OK (fuse box, near to clutch pedal) 3. Continuity between fuse 2 and pin 43 of the ECU = WAS OK 4. I have 12 volts on the blue wire coils (I have new colis and new spark plugs) 5. I checked the injectors and CAS = WAS OK I'm desperate because I do not know what else I can check. Someone can help me? Last edited by ferlepo; 02-23-2019 at 12:18 PM.. |
