![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Im doing my five speed swap in a day or two and have a question about the nismo line.
I have the nismo clutch line and the agency power line(removes the dampener). Im pretty sure but am not 100%, the nismo line eliminates the small rubber line that goes from the dampener to the slave right ? And where does the bleeder connector bolt to ? thanks for the help.
![]() Do you suffer from vaginal dryness... |
![]() Join Date: Dec 2002
There's a bleeder on the slave cylinder.
Trader Rating: (48)
Thats why I was asking, my nismo line came with a bleeder bolt and im not sure where it would go.
![]() Join Date: Aug 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
The agency power line go's from the master all the way to the slave, making it very easy to bleed from the slave cly.. The nismo line is if you only want to replace the small rubber line and keep the steel hard line. So try and sell the nismo line, through away the hard line and ONLY use the a p line.
Trader Rating: (48)
Trader Rating: (48)
my car is auto for another day or two, so i dont think it has all the dampener crap. I was going to delete it anyway.
Anyone need a brand new nismo line ?
Hey i might actually take that from you for my rb. Does this connect to the first mating block, aka the line that comes directly from the master, does this connect to the end of that, then go directly into the slave?
Aka Orig: Master -->block-->dampner line-->block-->softline-->slave Nismo: Master-------------------(hardline)-->Nismo--->Slave The nismo line will thread into the hardline where it connects to the first block, then thread into the slave? Sorry to repeat but i just called FR and Vivid and noone really knows the answer and i dont feel like waiting until i return home |
![]() Join Date: Nov 2004
If it's this one:
![]() Then yes. It connects to the clutch hardline, and the other end to the slave cylinder. |
You fried your clutch line because you don't have an engine ground?
