RB neo timing ignition is driving me CRAZY!!!
Im finishing my RB25det NEO and I'm stuck trying to set up the ignition timing. First the mods.
Freddy plenum Fmic Stock turbo Stock Maf Iacv Boost solenoid Stock throttle body Walbro fuel pump Fuel regulator set to 36psi idle 42psi wot Stock injectors Wiring specialist harness I already test the tps,cas, Maf, temp sensor and everything is ok. I double checked the mechanical timing and is onpoint. So I let the engine warm up (idle around 700rpm) turn it off, I disconnect the tps, start again rpms jump to 900 at idle. With my timing light connected and moving my cas I can retard it all the way (counterclockwise) and get 25*. I can't reach the 15*. The vacuum is almost 20 inhg at idle so I believe I don't have a leak, my fuel ratio is at 14.7 On my Nissan data scan show 5* timing. If I try to rev the engine fast it bogs and if I do it slow is ok. On my data scan I can run the base idle adjustments setting which automatically set the timing to 15* and revs perfect. After that the timing goes back to 5*. Any help will be appreciated Thanks!! Timing marks: Setup: |
![]() Join Date: Sep 2011
![]() Feedback Score: 20 reviews
If you take the cas cover off it has that disc looking thing with slots on it, it has like a half moon shape slot it can be put on backwards accidently
GO DUCKS!!!!!!!!!
Updated!!! I was able to set the cas to 15* but the Ecu keep making adjustments all the way to 5*. I'd try connecting the neutral sensor to the ecu but I was worse. I tested the knock sensors and are ok.
I already check the cas and is property install, also I check the wiring for the knock sensor and is fine as well.
Thanks for the help guys!! Keep the ideas coming please! |
It have to be a sensor or the ecu itself that is messing me up. When I use my consult (datascan) and run the base Idle it runs perfect!!!! Can a bad iacv mess my timing?
| neo, rb25, rb25 cas, timing |
