help, problem with rear noise, goes to the left when I accelerate...
Hi, im asking for ideas, my car is a 9f 180sx, problem started one day, when I accelerate, the car would go to the left without turning the wheel, if I let the gas pedal out, car would go to the right, so I had bad rear subframe bushings and installed energy suspension poly bushings, Also did a complete z32 brake upgrade out of a 91 Z, my car came with a nismo 2way lsd,tanabe sustec pro coilovers, the lsd clunks when turning at low speeds but that is normal on a 2 way, now the car does that when going straight along with the going left/ right problem
The subframe is straight, touching the chassis flush, checked lower control arm bushings, traccion rod bushings, etc and everything is ok, the driveshaft mount is also ok, the driveshaft doesnt vibrates, what can be wrong? Don't know what more can I do, thanks
